GDAL
November 11, 2015, 6:16am
1
#2795: v.krige fails to launch from wxgui menu if a vector map is selected
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: v.krige | CPU: Unspecified
Platform: Unspecified |
If in wxgui a vector map is selected and one starts v.krige from menu, the
name of vector map is passed to v.krige as an argument for G_OPT_V_INPUT.
As v.krige is using grass.parser to parse input, it causes failure as
other required parameters are not set (G_OPT_DB_COLUMN).
wxgui gurus - no idea how to fix, as v.krige is using custom GUI dialog
and thus just displaying standard grass.parser UI is not a solution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2795> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
November 22, 2015, 8:17pm
2
Priority: normal | Milestone: 7.0.3
Resolution: | Keywords: v.krige
Changes (by annakrat):
* milestone: => 7.0.3
Comment:
Should be fixed in 66894, but please test since I have some difficulties
in installing dependencies and I can't test much.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2795#comment:1> ;
GDAL
November 24, 2015, 7:36pm
3
Type: defect | Status: closed
Resolution: fixed | Keywords: v.krige
Changes (by marisn):
* status: new => closed
* resolution: => fixed
Comment:
Yes, works now with trunk.
Does it needs to be backported to 7.0 branch?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2795#comment:2> ;
GDAL
November 24, 2015, 7:44pm
4
Comment (by martinl):
Replying to [comment:2 marisn]:
Please don't close ticket, when you are asking such question
Ticket URL: <https://trac.osgeo.org/grass/ticket/2795#comment:3> ;
GDAL
November 24, 2015, 7:45pm
5
Type: defect | Status: reopened
Changes (by martinl):
* status: closed => reopened
* resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2795#comment:4> ;
GDAL
November 24, 2015, 8:34pm
6
* status: reopened => closed
Comment:
Backported in r66915.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2795#comment:5> ;
