[GRASS-dev] [GRASS GIS] #2797: db.databases will not connect to postgres database in GRASS 7.0.2RC2 on Win7 and Ubuntu 15.10
Reporter: pshapley | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Database | Version: svn-releasebranch70
Keywords: login database connection | CPU: x86-64
Platform: MSWindows 7 |
If i try to 'link external vector data' to a postgres driver i get the
following:-
db.databases location=db.databases driver=pg location=host="###.###.##
port=5432"
DBMI-PostgreSQL driver error:
Unknown option in database definition for PostgreSQL:
db.databases driver=pg location=host="###.###.## port=5432"
ERROR: Unable to list databases. Try to define correct connection settings
by db.login.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2797&gt;
  Priority: normal | Milestone: 7.0.3
Resolution: | Keywords: login database connection
       CPU: x86-64 | Platform: MSWindows 7
Comment (by harrikoo):
1. Your command line is incorrect. You write:
`db.databases location=db.databases driver=pg location=host="###.###.##
port=5432"`
and this should be
`db.databases driver=pg location="host=###.###.## port=5432"`
Note where the quotations marks are, both the `host` and the `port` must
be within the quotation marks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2797#comment:2&gt;
Description changed by neteler:
Old description:
following:-
port=5432"
settings by db.login.
New description:
following:-
port=5432"
by db.login.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2797#comment:3&gt;
Old description:
following:-
port=5432"
New description:
following:-
port=5432"
by db.login.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2797#comment:4&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: login database connection
Changes (by neteler):
* status: new => closed
* resolution: => invalid
Comment:
Closing due to user error. Feel free to reopen otherwise.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2797#comment:5&gt;
