[GRASS-dev] [GRASS GIS] #280: wxGUI doesn't handle removing maps
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
1. add an existing raster map in the manager
2. zoom to that map
2. g.remove it
3. "Re-render map" - error:
   File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/ma
pdisp.py", line 2871, in OnRender
self.MapWindow.UpdateMap(render=True)
pdisp.py", line 661, in UpdateMap
windres=windres)
   File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/re
nder.py", line 880, in Render
self._renderLayers(force, mapWindow, maps, masks, opacities)
nder.py", line 826, in _renderLayers
if not layer.Render():
nder.py", line 156, in Render
stderr=None)
   File
"/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/gcmd.py",
line 358, in __init__
_("Error: ") + self.GetError()))
UnicodeDecodeError
'ascii' codec can't decode byte 0xc5 in position 38: ordinal
not in range(128)
Ticket URL: <http://trac.osgeo.org/grass/ticket/280&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
That was problem with locales, fixed in r33255.
Ticket URL: <http://trac.osgeo.org/grass/ticket/280#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/280#comment:2&gt;
