[GRASS-dev] [GRASS GIS] #2801: wxGUI modeler: overwrite flag not saved when reopening module dialog
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.1
Keywords: modeler overwrite flag | CPU: Unspecified
Platform: Unspecified |
In the GUI modeler:
* add any module
* in the module dialogue check the overwrite flag checkbox
* close the module dialogue
* reopen the module dialogue
Result: the overwrite flag is not checked anymore. You have to explicitely
set the flag everytime you reopen a module dialogue. Very annoying...
I have this issue in 7.0.1 and cannot verify whether this is also an issue
in trunk because of #2800.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801&gt;
Resolution: | Keywords: modeler overwrite flag
Comment (by martinl):
There were two issues - wxGUI part fixed in r66941. Moreover
`G_recreate_command()` ignored global options (like `--overwrite`), this
issue is fixed r66940. After some testing I will backport both changes to
relbr70.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:1&gt;
Replying to [ticket:2801 mlennert]:
explicitely set the flag everytime you reopen a module dialogue. Very
annoying...
Please note that you can set overwrite globally for model in `Model ->
Properties` (Graphical Modeler) or for whole GUI in `GUI Preferences ->
Modules` (Layer Manager).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:2&gt;
  Reporter: mlennert | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* owner: grass-dev@… => martinl
* cc: grass-dev@… (added)
* status: new => assigned
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:3&gt;
Comment (by wenzeslaus):
Replying to [comment:2 martinl]:
annoying...
BTW, I think the global settings is a best practice and should be
preferred.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:4&gt;
Comment (by mlennert):
Replying to [comment:4 wenzeslaus]:
annoying...
preferred.
Are you speaking about the global setting in the modeler or for the whole
GUI ?
In both cases I strongly disagree. IMHO, automatic overwrite should not be
the default setting. It should always be a deliberate choice by the user.
Thank you for the fixes, Martin, I'll test as soon as possible.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:5&gt;
Replying to [comment:1 martinl]:
relbr70.
A quick test shows that both the modeler fix and the general lib fix seem
to work here.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:6&gt;
Replying to [comment:5 mlennert]:
annoying...
-> Properties` (Graphical Modeler) or for whole GUI in `GUI Preferences ->
preferred.
whole GUI ?
be the default setting. It should always be a deliberate choice by the
user.
`Model -> Properties` applies just to the current model (global for the
whole model), right? If the alternative is overwrite checked for every
individual module, then yes, I think it is better.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: modeler overwrite flag
* status: assigned => closed
* resolution: => fixed
Comment:
relbr70.
Both issues backported (r67374 and r66981). Closing this ticket, feel free
to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2801#comment:8&gt;
