[GRASS-dev] [GRASS GIS] #2815: Grass and Pillow > 3.0.0
Reporter: pmav99 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version:
Keywords: animation | CPU: All
Platform: Unspecified |
Pillow since version 3.0.0 removed the `fromstring()` method[1]. AFAIK the
only usage of the `fromstring()` method in GRASS in g.gui.animation:
$ ag fromstring
[omit etree.fromstring() results]
gui/wxpython/animation/utils.py
263: pilImage.fromstring(image.GetData())
I believe it is rather safe to replace the call with `frombytes()`. If we
need to keep compatibility with the original PIL I guess that something
like this would do it:
def WxImageToPil(image):
     """Converts wx.Image to PIL image"""
     pilImage = Image.new('RGB', (image.GetWidth(), image.GetHeight()))
     try:
         pilImage.frombytes(image.GetData())
     except Exception:
         # We are using the original Pil or an old Pillow version
     return pilImage
[1] https://github.com/python-
pillow/Pillow/commit/71c95c8e5f3bba1845444a246d04646825e6bab3
Ticket URL: <https://trac.osgeo.org/grass/ticket/2815&gt;
Component: wxGUI | Version: unspecified
Resolution: | Keywords: animation
       CPU: All | Platform: Unspecified
Changes (by pmav99):
* version: => unspecified
Comment:
This should be the exact same issue:
http://osgeo-org.1560.x6.nabble.com/d-mon-using-PIL-tostring-not-used-
anymore-tobytes-to-be-used-td5239514.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/2815#comment:1&gt;
Resolution: | Keywords: animation, PIL
Changes (by annakrat):
* keywords: animation => animation, PIL
Comment:
Fixed in r67012. Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2815#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: animation, PIL
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2815#comment:3&gt;
      Type: defect | Status: reopened
Changes (by neteler):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:3 pmav99]:
> Resolution set to fixed
> Status changed from new to closed
Didn't you want the fix also in 7.0? The backport has not happened yet, so
please don't close the ticket yet. Or is no backport wanted?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2815#comment:4&gt;
* status: reopened => closed
Comment:
Backported in r67035.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2815#comment:5&gt;
