[GRASS-dev] [GRASS GIS] #2820: r.surf.idw gives broken results - Don't match v.surf.idw
Reporter: lrntct | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.3
Component: Raster | Version: 7.0.1
Keywords: | CPU: x86-64
Platform: Linux |
I've encountered some strange problem with r.surf.idw while trying to
interpolate rainfall data.
That is the procedure:
- import raster points with r.in.xyz
- convert to integer with r.mapcalc, multiplying value by 10^6
- run r.surf.idw
- convert back to float with r.mapcalc
- convert original raster points to vector using r.to.vect
- run v.surf.idw
- set same color table to both rasters
Images of the results are attached
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820&gt;
Resolution: | Keywords:
       CPU: x86-64 | Platform: Linux
Changes (by lrntct):
* Attachment "r.surf.idw.png" added.
results from r.surf.idw
* Attachment "v.surf.idw.png" added.
Comment (by wenzeslaus):
Can you please provide a simple shell script with the steps so that this
can be easily repeated?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:1&gt;
Comment (by mlennert):
I can reproduce the issue in the NC data set:
g.region vect=nc_state res=500 -a
v.surf.idw precip_30ynormals col=annual out=vsurfidw --o
v.to.rast precip_30ynormals use=attr attr_col=annual out=precip --o
r.mapcalc "precip_int = int(precip * 100)" --o
r.surf.idw in=precip_int out=rsurfidw_tmp --o
r.mapcalc "rsurfidw = float(rsurfidw_tmp) / 100" --o
r.mapcalc "diff = rsurfidw - vsurfidw"
Analysing the differences, you get:
r.univar map=diff
total null and non-null cells: 24840200
total null cells: 0
Of the non-null cells:
n: 24840200
minimum: -370.28
maximum: 1020.98
range: 1391.26
mean: 48.8595
mean of absolute values: 127.803
standard deviation: 180.027
variance: 32409.7
variation coefficient: 368.458 %
sum: 1213680178.7663
and
r.covar -r map=rsurfidw,vsurfidw
r.covar: complete ...
N = 24840200
1.000000 0.284021
0.284021 1.000000
Looking at the individual result maps:
r.univar map=rsurfidw
total null cells: 0
n: 24840200
minimum: 947.42
maximum: 2329.17
range: 1381.75
mean: 1346.31
mean of absolute values: 1346.31
standard deviation: 183.013
variance: 33493.9
variation coefficient: 13.5937 %
sum: 33442685677.211
and
r.univar map=vsurfidw
total null cells: 0
n: 24840200
minimum: 1120.14
maximum: 1546.86
range: 426.72
mean: 1297.45
mean of absolute values: 1297.45
standard deviation: 92.1991
variance: 8500.67
variation coefficient: 7.10616 %
sum: 32229005498.4201
I will also attach some maps, including a map of the original data points.
The interpolated maps use the following color table:
947.42 255:255:255
2329.17 0:0:255
v.surf.idw smoothes the map much more...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:2&gt;
Changes (by mlennert):
* Attachment "idw_tests_NCdata.png" added.
maps of NC data test
Comment (by neteler):
Looking at the "r.surf.idw.png​" attachment: could it be that some integer
rounding happens (just guessing)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:3&gt;
Comment (by lrntct):
Here is a way to reproduce the problem:
v.in.ascii input=rainfall2.csv output=stations_vect separator=comma z=3
g.region vector=stations_vect res=100
v.surf.idw input=stations_vect output=vsurfidw
v.to.rast input=stations_vect output=stations_rast use=z
r.mapcalc expression='stations_int=int(stations_rast*1000000)'
r.surf.idw input=stations_int output=rsurfidw_int
r.mapcalc expression='rsurfidw=double(rsurfidw_int)/1000000'
r.mapcalc expression='rain_diff=rsurfidw-vsurfidw'
r.colors map=rain_diff color=aspect
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:4&gt;
#2820: v.surf.idw results seem seriously wrong and don't match r.surf.idw results
  Priority: blocker | Milestone: 7.0.3
Component: Vector | Version: 7.0.1
Resolution: | Keywords: v.surf.idw r.surf.idw interpolation
* keywords: => v.surf.idw r.surf.idw interpolation
* priority: major => blocker
* component: Raster => Vector
Comment:
The more I look at this issue, the more I get the feeling that v.surf.idw
is wrong as well. At least, I cannot really explain the output for the NC
precipitation data shown in
[https://trac.osgeo.org/grass/attachment/ticket/2820/idw_tests_NCdata.png
idw_tests_NCdata.png].
Here's a test using the NC precipitation data interpolated to maps
rsurfidw and vsurfidw according to above instructions (tested in trunk):
echo "673491|55508" | v.in.ascii in=- out=test_interpolation
v.db.addtable test_interpolation
v.db.addcolumn test_interpolation col="idw_vect double precision"
v.db.addcolumn test_interpolation col="idw_rast double precision"
v.db.addcolumn test_interpolation col="owncal double precision"
v.what.rast test_interpolation col=idw_vect rast=vsurfidw
v.what.rast test_interpolation col=idw_rast rast=rsurfidw
v.db.update test_interpolation col=owncal value=$(v.distance -p -a
from=test_interpol@user1 to=precip_30ynormals@PERMANENT dmax=102000
upload=dist,to_attr to_column=annual --quiet | tail -n +2 | awk -F'|'
'BEGIN{sumvals=0;sumweights=0} {weight=1/$3^2;sumweights+=weight;
sumvals+=weight*$4} END{print sumvals/sumweights}')
v.db.select test_interpolation
The result is quite unambiguous:
cat|idw_vect|idw_rast|owncal
1|1545.09361138162|1388.6|1389.27
i.e. the calculated value is almost exactly identical to the r.surf.idw
result, while the v.surf.idw result is very far off.
I would guess the segmentation observed by the OP with r.surf.idw is due
to integer rounding issues (although this should be explored), but in the
current state, v.surf.idw needs a serious check to see where the error
comes from !
I'm renaming this ticket for now, but maybe it needs to be split in two...
Bumping it up as a blocker, since this is basic functionality of a GIS
which should "just work"...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:5&gt;
Replying to [comment:5 mlennert]:
Using the '-n' flag in v.surf.index seems to solve the issue at least
partly: the value for the above point is now 1421, i.e. much closer to the
r.surf.idw and the calculated result (although still significantly
different).
More exploration needed...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2820#comment:6&gt;
Replying to [comment:6 mlennert]:
r.surf.idw result, while the v.surf.idw result is very far off.
different).
Ok, found part of the problem: distance was always left as dy*dy + dx*dx
without ever taking the square root. This obviously changes the weights as
1/10 is closer to 1/100 than 1/100 is to 1/10000...
The following patch solves this issue. Now I get the same result using the
-n flag as I do by calculation and with r.surf.idw. Without the -n flag I
now have a value of 1484 instead of the 1545 above. Indexing thus still
causes some issues. I think that these should be explored before applying
below patch. As an intermediate solution we could apply this immediately
and either reverse the meaning of the -n flag, making no indexing the
default, or we just completely take away the -n flag and always work
without indexing.
Index: vector/v.surf.idw/main.c
--- vector/v.surf.idw/main.c (révision 67143)
+++ vector/v.surf.idw/main.c (copie de travail)
@@ -468,7 +468,7 @@
         if (i < nsearch) {
             dy = points[row][column][j].north - north;
             dx = points[row][column][j].east - east;
- list[i].dist = dy * dy + dx * dx;
+ list[i].dist = sqrt(dy * dy + dx * dx);
             list[i].z = points[row][column][j].z;
             i++;
@@ -486,7 +486,7 @@
             /* go thru rest of the points now */
- dist = dy * dy + dx * dx;
+ dist = sqrt(dy * dy + dx * dx);
             if (dist < maxdist) {
                 /* replace the largest dist */
@@ -514,7 +514,7 @@
      for (i = 0; i < nsearch; i++) {
         dy = noidxpoints[i].north - north;
         dx = noidxpoints[i].east - east;
         list[i].z = noidxpoints[i].z;
      /* find the maximum distance */
@@ -527,7 +527,7 @@
      for (; i < npoints; i++) {
As Paul is the one who introduced indexing, maybe he wants to comment...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:7&gt;
Paul,
Do you have any opinion on this ?
-------- Forwarded Message --------
Subject: Re: [GRASS-dev] [GRASS GIS] #2820: v.surf.idw results seem seriously wrong and don't match r.surf.idw results
Date: Tue, 15 Dec 2015 16:08:07 -0000
Reply-To: grass-dev@lists.osgeo.org
  > Replying to [comment:5 mlennert]:
  > > The result is quite unambiguous:
  > > cat|idw_vect|idw_rast|owncal
  > > 1|1545.09361138162|1388.6|1389.27
  > > i.e. the calculated value is almost exactly identical to the
  > Using the '-n' flag in v.surf.index seems to solve the issue at least
  different).
  > More exploration needed...
  without indexing.
  @@ -468,7 +468,7 @@
          if (i < nsearch) {
              i++;
  @@ -486,7 +486,7 @@
  @@ -514,7 +514,7 @@
  @@ -527,7 +527,7 @@
grass-dev mailing list
Comment (by pkelly):
Hi Moritz, Thanks for bringing this to my attention. Looks like the bug
with the squared distance was introduced when support for powers other
than 2 was added in r32957, and ported to GRASS 7 in r59107.
Regarding the indexing, it's certainly true that it can give slightly
different results depending on the layout of the points, and looking back
maybe it shouldn't have been made the default mode of operation because of
these differences. E.g. one obvious issue is that only points inside the
current region are included in the interpolation, whereas without indexing
all points are potentially included even if they lie outside the region.
And I guess it's still possible there could be a bug in it somewhere as my
programming skills weren't quite so well developed back then either.
I haven't been able to test the example in the Trac ticket yet as I don't
have GRASS 7 currently installed, only 6.4, and the GRASS6 version of the
NC dataset at
<https://grass.osgeo.org/sampledata/north_carolina/nc_spm_latest.tar.gz&gt;,
when uncompressed, seems to be actually the same as the GRASS7 version.
My original interpolation use case was image pixels from a ground-level
camera view that had been perspective-transformed to an overhead view,
resulting in highly uneven point density across the region. Without the
indexing s.surf.idw (as it was then) could take hours to run. The
following extract from my PhD thesis gives some of the background:
http://www.stjohnspoint.co.uk/gis/idw.pdf (although at the Firefox built-
in PDF viewer seems to have trouble displaying it; it's converted from the
original PostScript).
One thing I would consider testing first if I had the data, would be to
enlarge the region to slightly bigger than the edges of the point cloud
(i.e. slightly bigger than the result of g.region vect=stations_vect),
just in case there were any rounding issues with points right at the edge
falling out of the region and not being included in the indexing.
Paul
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:8&gt;
Replying to [comment:8 pkelly]:
Indeed. Before that, no need to take the square root if it was to only
square the distance afterwards...
don't have GRASS 7 currently installed, only 6.4, and the GRASS6 version
of the NC dataset at
Yes, that's a bug. Running v.build.all in the PERMANENT mapset solves that
easily, though.
The interpolation was done in a region defined by the nc_state boundary:
g.region vect=nc_state res=500 -ap
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 318500
south: 10500
west: 124000
east: 930500
nsres: 500
ewres: 500
rows: 616
cols: 1613
cells: 993608
Setting the region with station data gives:
g.region vect=precip_30ynormals res=500 -a
zone: 0
datum: nad83
north: 306500
south: 27500
west: 151500
east: 917500
nsres: 500
ewres: 500
rows: 558
cols: 1532
cells: 854856
so, I don't think that this is the issue, here.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:9&gt;
* Attachment "test_vsurfidw_grass6.sh" added.
Complete testing script for GRASS6
* Attachment "test_vsurfidw_grass7.sh" added.
Complete testing script for GRASS7
I've just added complete testing scripts for GRASS6 and GRASS7.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:10&gt;
Replying to [comment:9 mlennert]:
that easily, though.
See #2829.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:11&gt;
Sorry for the mess. Fixed now (see #2829).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:12&gt;
Investigating further. Adding the following patch for diagnosis (in
addition to the above sqrt patch):
Index: main.c
--- main.c (révision 67166)
+++ main.c (copie de travail)
@@ -386,6 +386,7 @@
                 sum1 = 0.0;
                 sum2 = 0.0;
                 for (n = 0; n < nsearch; n++) {
+ fprintf(stdout, "%f,%f,%f,%f\n", east, north,
list[n].dist, list[n].z);
                     if ((dist = list[n].dist)) {
                         sum1 += list[n].z / pow(dist, p);
                         sum2 += 1.0 / pow(dist, p);
and then running the following commands (i.e. creating one vector point
and getting distance and annual precipitation values from the 12 nearest
stations to that point, as well as the same values for the equivalent
pixel in both runs of v.surf.idw (without and with -n flag):
echo "567250|214750" | v.in.ascii in=- out=center --o
v.distance -ap from=center to=precip_30ynormals up=dist,to_attr
to_col=annual dmax=64000 --q | tail -n -12
v.surf.idw precip_30ynormals col=annual out=vsurfidw --o > list.csv
v.surf.idw -n precip_30ynormals col=annual out=vsurfidw_noindex --o >
list.csv
grep "567250.000000,214750" list.csv > list_center.csv
grep "567250.000000,214750" list_noindex.csv > list_center_noindex.csv
and putting together the results of the v.distance, v.surf.idw and
v.surf.idw -n runs, I get (results ordered by increasing distance):
* v.distance
distance value
8400,5853273955 1224,28
33001,5791065737 1183,64
33543,2163702733 1183,64
39603,9217121153 1234,44
41429,8528851821 1158,24
41667,8156183992 1206,5
41677,4928801831 1143
42993,6439600215 1209,04
55288,6854942564 1170,94
58543,7865733219 1216,66
60471,6142897 1219,2
62763,095429678 1094,74
* v.surf.idw
distance value
80047,835648 1191,26
90264,15377 1183,64
91013,285596 1158,24
99493,013889 1219,2
120304,207816 1120,14
171007,225542 1358,9
183102,228906 1440,18
184179,357051 1170,94
194397,039723 1234,44
200403,915046 1163,32
230189,059243 1546,86
231312,997387 1259,84
* v.surf.idw -n
8400,585327 1224,28
33001,579107 1183,64
33543,21637 1183,64
39603,921712 1234,44
41429,852885 1158,24
41667,815618 1206,5
41677,49288 1143
42993,64396 1209,04
55288,685494 1170,94
58543,786573 1216,66
60471,61429 1219,2
62763,09543 1094,74
In other words, v.surf.idw -n gives the exact same values as v.distance,
but v.surf.idw without the flag gives a completely different set of
distances. So, I have the feeling that the issue is in the
[https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.surf.idw/main.c#L458
calculate_distances()] function or possibly in the creation of the
[https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.surf.idw/main.c#L187
shortlist of cells to look in] in main.c, but I haven't been able to
pinpoint the culprit, yet.
Any help is more than welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2820#comment:13&gt;
