#2826: wxGUI: encoding issues
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.2
Keywords: encoding | CPU: Unspecified
Platform: Unspecified |
I'm getting bitten by quite a lot of encoding issues in the wxGUI lately.
I'm putting them here into one bug report as they all seem to have a
similar pattern, but I can split up into separate bug reports if
necessary.
Here are two examples using freshly checked out trunk (but I can reproduce
in grass70_release and in grass 7.0.2 - all with locale fr_BE.utf8):
* v.to.rast/r.to.vect: just launching the module makes three error windows
pop up with "'ascii' codec can't decode byte 0xc3 in position 8: ordinal
not in range(128)". After clicking through the three messages, I can
launch the command. In the console I get:
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
-unknown-linux-gnu/gui/wxpython/gui_core/forms.py", line
2267, in OnSetValue
self.OnUpdateValues(event)
629, in updateValuesHook
self.SetStatusText(' '.join(map(gcmd.DecodeString,
self.notebookpanel.createCmd(ignoreErrors = True))))
TypeError
argument 2 to map() must support iteration
2267, in OnSetValue
TypeError
2094, in OnUpdateDialog
self.parent.updateValuesHook()
TypeError
* d.rgb: same error pop-up, just once, same error message in console (see
below). However, when I choose a raster band I get the same pop-up window
which is blocked from view by the layer list selector and so I cannot
click on the 'OK' button. Any GUI programme I have open is then completely
blocked, only terminal is accessible allowing me to kill the process. This
basically makes d.rgb unusable for me in the wxGUI.
TypeError
I'll add others if I stumble upon them.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2826>
