#2827: wxGUI: encoding error in error messages
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: svn-releasebranch70
Keywords: encoding | CPU: Unspecified
Platform: Unspecified |
In several modules, whenever I try to launch the module with missing
parameters, I get an error message as such in the command console of the
wxGUI, but no error message in the module output tab:
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
-unknown-linux-gnu/gui/wxpython/gui_core/forms.py", line
696, in OnRun
cmd = self.createCmd()
791, in createCmd
ignoreRequired = ignoreRequired)
2344, in createCmd
message = unicode(err),
UnicodeDecodeError
'ascii' codec can't decode byte 0xc3 in position 8: ordinal
not in range(128)
Reproduced with trunk, grass70_release and grass 7.0.2 with locale
fr_BE.utf8.
I assume there is no "evil" char in po file. This is just another "ups! I
forgot to deal with incoming string encoding" type error in python code.
Although I can not reproduce the issue, it can depend on 1) particular
string; 2) locale; 3) return of python's
getlocadedefaultencodingwhatinmostofcasesistotallywronganyway.
Moritz - please, provide exact command exposing the issue. Also take a
look if it isn't a duplicate of #2800#2727#2617#2390#2120#1856#1672 #1488 or #1293
Replying to [comment:3 annakrat]:
> Fixed in r67187, tested on linux only so far.
Now, when *starting* v.buffer it is ok but clicking on "Run" ("Exécuter"),
even without anything set, still triggers it (Linux with Python: 2.7.10,
wxPython: 3.0.2.0 ).
Replying to [comment:4 neteler]:
("Exécuter"), even without anything set, still triggers it (Linux with
Python: 2.7.10, wxPython: 3.0.2.0 ).
Fixed in r67205. But we need to test it on Windows as well.
Replying to [comment:5 annakrat]:
Yes, thanks, works for me on GNU/Linux. I don't have the opportunity to
test on Windows at the moment.
OK, my mistake, r67262 should fix this correctly and it's tested on
Windows. Moritz, could you go through the tickets related to this
(suggested above), test and update which ones are to be closed?
