[GRASS-dev] [GRASS GIS] #2834: v.db.select comand works, sqlite, attribute table does not open
Reporter: khe | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Database | Version: 7.0.2
Keywords: | CPU: Unspecified
Platform: Linux |
Hey,
I imported vector data by using the Python Shell
g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_clip_strasse.shp",
output=ort+"_strasse",overwrite=True, type="line",flags="o")
g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_gewaesserordnung.shp",
output=ort+"_gewaesser",overwrite=True, type="line",flags="o")
g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_gewasserachse.shp",
output=ort+"_gewaesserachse",overwrite=True, type="line",flags="o")
g.run_command("v.in.ogr", dsn=loc2+"Schoenbuch_weg.shp",
output=ort+"_weg",overwrite=True, type="line",flags="o")
The database sqlite is connected (v.db.connect), I can open the vector
layer, but cannot open the attribute table, but the command v.db.select
works without having any problems.
It says: "DMBI-SQLite driver error: Unable to scan data: Fehler: Kann
Daten nicht aus der Tabelle <S_weg> holen.
What could be the reason? Did anybody of you had similar problems?
Thanks for your help.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834&gt;
  Priority: normal | Milestone: Website
Resolution: | Keywords:
       CPU: Unspecified | Platform: Linux
Changes (by khe):
* milestone: 7.0.3 => Website
Ticket URL: <http://trac.osgeo.org/grass/ticket/2834#comment:1&gt;
Resolution: | Keywords: v.in.ogr
Changes (by martinl):
* keywords: => v.in.ogr
* milestone: Website => 7.0.3
Old description:
Hey,
New description:
Hey,
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:2&gt;
Comment (by martinl):
Replying to [ticket:2834 khe]:
btw, why do you use `o` flag?
Please exact command which fails.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:3&gt;
Comment (by khe):
Hey Martin, thanks for your answer.
  <btw, why do you use o flag?
I used the "o"-flag in order to override dataset projection (use
location's projection).
The command itself ("v.in.ogr") is working. I can open the vector-data of
the the streams, roads...
BUT I cannot open the attribute table by using the sqlite-database. I
connected the sqlite-database, the command "v.db.select" is working.
When I want to open the attribute table a window opens saying "DMBI-SQLite
driver error: Unable to scan data...".
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:4&gt;
Comment (by mlennert):
Would it be possible for you to share a shapefile that creates the issue,
so that we can try to reproduce ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:5&gt;
Changes (by khe):
* Attachment "Schoenbuch_weg.shp" added.
shp-file
Changes (by khe):
* Attachment "Schoenbuch_weg.2.shp" added.
Comment (by hellik):
Replying to [comment:4 khe]:
of the the streams, roads...
SQLite driver error: Unable to scan data...".
     Anhang Schoenbuch_weg.shp​ hinzugefügt
shp-file
according to https://en.wikipedia.org/wiki/Shapefile#Overview for a
working ''shapefile'' following files are needed at least:
     .shp — shape format; the feature geometry itself
     .shx — shape index format; a positional index of the feature geometry
to allow seeking forwards and backwards quickly
     .dbf — attribute format; columnar attributes for each shape, in dBase
IV format
could you post all 3 files (zipped) to test?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:6&gt;
Changes (by khe):
* Attachment "trail.dbf" added.
Changes (by khe):
* Attachment "trail.sbx" added.
Comment (by khe):
Thanks for this advice. Do you think I cannot open the attribute table,
because I only imported the .shp-format? Why does it work by using the
dbf-database?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:7&gt;
Comment (by pvanbosgeo):
I cannot open the shapefile (the three files) you send in QGIS or GRASS.
Probably because the *.shx file is missing. But also note that the three
files (.shp, .shx, .dbf) should have the same name. The .shp file you
shared has another name than the .dbf and .sbx files.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:8&gt;
Changes (by khe):
* Attachment "trail.shp" added.
Changes (by khe):
* Attachment "trail.shx" added.
I can confirm your error with the trail shapefile, although for me
v.db.select also fails:
v.db.select
trailcat|object_id|gml_id|objektart|objektname|funktion_i|funktion_n|befestigun|befestig_1|art_id|art_name|breite|eigenname|kennung|gml_id_unt|unten_name|klasse|beginn|ende|SHAPE_STLe
DBMI-SQLite erreur de pilote :
Unable to scan date:
ERREUR :Unable to fetch data from table <trail>
Setting DEBUG to 3 I get the following:
D3/3: col: SHAPE_STLe, nkcols 19, litetype : 2, sqltype 6
D3/3: fetch row = -1
D3/3: col 0, litetype 1, sqltype 3: val = '1'
D3/3: col 1, litetype 3, sqltype 1: val =
'0c6d5762-d8cb-4554-a559-45010a046a4d'
D3/3: col 2, litetype 3, sqltype 1: val = 'DEBWB0010000LRl3'
D3/3: col 3, litetype 1, sqltype 3: val = '42008'
D3/3: col 4, litetype 3, sqltype 1: val = 'Fahrwegachse'
D3/3: col 5, litetype 1, sqltype 3: val = '5211'
D3/3: col 6, litetype 3, sqltype 1: val = 'Hauptwirtschaftsweg'
D3/3: col 7, litetype 1, sqltype 3: val = '0'
D3/3: col 8, litetype 3, sqltype 1: val = ''
D3/3: col 9, litetype 1, sqltype 3: val = '0'
D3/3: col 10, litetype 3, sqltype 1: val = ''
D3/3: col 11, litetype 2, sqltype 6: val = '6.0'
D3/3: col 12, litetype 3, sqltype 1: val = '; ForstBW'
D3/3: col 13, litetype 3, sqltype 1: val = ''
D3/3: col 14, litetype 3, sqltype 1: val = 'DEBWB0010000BTEi'
D3/3: col 15, litetype 3, sqltype 1: val = 'Brücke'
D3/3: col 16, litetype 1, sqltype 3: val = '11190'
D3/3: col 17, litetype 3, sqltype 9: val = '2014-09-24'
D3/3: sqlite fetched date: <2014-09-24>
D3/3: col 18, litetype 3, sqltype 9: val = ''
D3/3: sqlite fetched date: <>
I can see that there is a problem with the 19th column which is 'ende'.
The programme cannot read the column as a date. This column is empty, but
it is not considered as NULL (no value), but as '' (empty string value).
I tried setting the column explicitely to NULL using v.db.update:
v.db.update trail col=ende value=NULL
but I still get the same error with v.db.select.
However, when I set the column to NULL using db.execute
db.execute sql="UPDATE trail SET ende=NULL"
v.db.select runs as expected.
So, there seems to be a problem with the NULL handling. When I open the
shapefile in QGIS, the ende column values are all marked as 'NULL'.
Somehow, either v.in.ogr or the sqlite driver seems to create a confusion
between NULL and an empty string.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2834#comment:9&gt;
Replying to [comment:9 mlennert]:
See #2850 for the relevant bug report.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:10&gt;
See #2851.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:11&gt;
Comment (by khe):
Thanks you so much. I would not be able to solve the problem on my own.
Have a nice day.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:12&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.0.7
Resolution: invalid | Keywords: v.in.ogr
* status: new => closed
* resolution: => invalid
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:18&gt;
