[GRASS-dev] [GRASS GIS] #2839: r.watershed: calculating stream power index crashes
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Raster | Version: svn-trunk
Keywords: r.watershed | CPU: x86-64
Platform: MSWindows 7 |
tested with in the NC sample data set
System Info
GRASS version: 7.1.svn
GRASS SVN revision: 67403
Build date: 2015-12-29
Build platform: i386-w64-mingw32
GDAL: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
g.region -p -a raster=elevation@PERMANENT align=elevation@PERMANENT
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 228500
south: 215000
west: 630000
east: 645000
nsres: 10
ewres: 10
rows: 1350
cols: 1500
cells: 2025000
r.watershed elevation=elevation@PERMANENT spi=spi_w32bit
SECTION 1a (of 4): Initiating Memory.
SECTION 1b (of 4): Determining Offmap Flow.
SECTION 2: A* Search.
SECTION 3a: Accumulating Surface Flow with MFD.
SECTION 3b: Adjusting drainage directions.
WARNING: Unable to execute command
WARNING: Subprocess failed with exit code -1073741819
WARNING: category information for [spi_w32bit] in [spitest] missing or
invalid
will test it also with set=DEBUG=3 and winGRASS7trunk 64bit
Ticket URL: <https://trac.osgeo.org/grass/ticket/2839&gt;
Resolution: | Keywords: r.watershed
       CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [ticket:2839 hellik]:
> System Info
> GDAL: 1.11.3
> PROJ.4: 4.9.2
> GEOS: 3.5.0
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
also tested with winGRASS 64bit
Build platform: x86_64-w64-mingw32
GDAL: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
r.watershed --verbose elevation=elevation@PERMANENT spi=spi_64bit
WARNING: category information for [spi_64bit] in [landsat] missing or
invalid
r.watershed also crashes here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2839#comment:1&gt;
Replying to [comment:1 hellik]:
some further test with -m flag:
r.watershed -m elevation=elevation@PERMANENT spi=spi_32bit_flagm
SECTION 1 beginning: Initiating Variables. 4 sections total.
SECTION 1a: Mark masked and NULL cells
SECTION 1b: Determining Offmap Flow.
SECTION 4: Closing Maps.
Closing SPI map
(Wed Dec 30 11:10:31 2015) Command finished (1 min 17 sec)
r.watershed -m elevation=elevation@PERMANENT spi=spi_64bit_flagm
Closing SPI map
(Wed Dec 30 11:12:25 2015) Command finished (9 sec)
it seems stream power index calculation in r.watershed works with -m flag
(Enable disk swap memory option) in both 32bit and 64bit winGRASS7trunk,
but not in normal mode.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2839#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 hellik]:
flag (Enable disk swap memory option) in both 32bit and 64bit
winGRASS7trunk, but not in normal mode.
Stupid segfault, should be fixed in r67919.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2839#comment:3&gt;
Replying to [comment:3 mmetz]:
tested with
GRASS SVN revision: 68008
Build date: 2016-03-08
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
r.watershed elevation=elevation@PERMANENT spi=streampower
(Tue Mar 08 10:38:52 2016) Command finished (4 sec)
(Tue Mar 08 10:39:49 2016)
r.watershed -m elevation=elevation@PERMANENT spi=streampowerms
Closing SPI map
(Tue Mar 08 10:40:03 2016) Command finished (13 sec)
bug fixed, closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2839#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.watershed
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2839#comment:5&gt;
