#2840: Workspace file issue
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: workspace, display | CPU: Unspecified
Platform: Linux |
When loading an existing workspace, the map display is cropped to the
upper left corner. The issue should not affect most recent wxpython
versions (mine is 3.0.2).
Priority: normal | Milestone: 7.2.3
Resolution: | Keywords: workspace, display
CPU: Unspecified | Platform: Linux
Comment (by balagates):
This issue still exists in 7.4.0. Opening a workspace where the display
size has been changed to be larger than the default results in a display
size as expected but only a portion of the display window being used.
Resizing the display window, even very slightly, updates things so the
entire display window is used.
