#2852: ps.map fit frame to match region doesn't work
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Ps.map | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Linux |
In ps.map fitting the frame to match the current region (or saved region)
doesn't work. It generates the error code below. It looks like it has
something to do with the code getting the degrees in DMS format instead of
the D format when presumably setting the bounds.
File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/psmap/d
ialogs.py", line 578, in OnApply
ok = self.mPanel.update()
ialogs.py", line 1065, in update
self.scale[2], self.center[2], self.rectAdjusted =
AutoAdjust(self, scaleType = 2, rect =
self.mapFrameDict['rect'])
File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/psmap/u
tils.py", line 222, in AutoAdjust
regionDict = grass.parse_key_val(windFile, sep = ':',
val_type = float)
File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/scr
ipt/utils.py", line 224, in parse_key_val
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by pvanbosgeo):
The limits of the region are taken from the Wind file. However, in this
file the coordinates are given in degrees:minutes, which is obviously not
a float type.
