[GRASS-dev] [GRASS GIS] #2853: ps.map ommits vector boundary/line where it overlaps with map frame
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
If I add a vector layer in ps.map which contains vector boundaries that
overlap with the border of the map frame, and deselects the option to draw
a border around the map frame, the part of the vector boundary that
overlaps with the map frame border is also not drawn (compare A with B in
the attached image).
Not sure it helps, but if I save the map as ps file and open it in
Inkscape, that part of the boundary still seems to be missing. However,
when I ungroup the map (you'll need to select ungroup several times), the
boundary shows up, so it seems hidden rather than removed/absent
Ticket URL: <https://trac.osgeo.org/grass/ticket/2853&gt;
Resolution: | Keywords:
Changes (by pvanbosgeo):
* Attachment "example.png" added.
Example where
  Priority: normal | Milestone: 7.6.2
Changes (by martinl):
* milestone: 7.0.7 => 7.6.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2853#comment:6&gt;
