GDAL
1
#286: vdigit: changing a tool should cancel current edits
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
r33285
1. add a vertex on a boundary
2. don't confirm with the right key, but select the "Move vertex" tool
3. try to drag the vertex you added - failure:
File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/ma
pdisp.py", line 1025, in MouseActions
self.OnLeftUp(event)
pdisp.py", line 1400, in OnLeftUp
self.moveCoords = (self.moveCoords[0] + dx,
IndexError
list index out of range
Selecting a different tool without committing the edit first (like in the
case above), should automatically cancel the uncommited edits edits.
Ticket URL: <http://trac.osgeo.org/grass/ticket/286>
GDAL
2
Reporter: msieczka | Owner: martinl
Type: defect | Status: assigned
Resolution: | Keywords:
Platform: All | Cpu: All
Changes (by martinl):
* status: new => assigned
* owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Fixed in r36423 (relbr64) r36424 (devbr6) and r36425 (trunk).
Ticket URL: <http://trac.osgeo.org/grass/ticket/286#comment:1>
GDAL
3
Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: assigned => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/286#comment:2>
