[GRASS-dev] [GRASS GIS] #2861: Copy 'Windows batchfiles for use with R' (GRASS-R-integration) from source to PACKAGE_DIR\extrabin not done
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Packaging | Version: svn-releasebranch70
Keywords: | CPU: Unspecified
Platform: MSWindows 7 |
hi,
in [1]ff files for a winGRASS-R-integration should be copied:
copy %OSGEO4W_BLD_DIR%\usr\src\grass70_release\mswindows\external\rbatch\*
%PACKAGE_DIR%\extrabin
but they aren't there.
tested in 7.0.3.RC1 and
GRASS Version: 7.0.3svn
GRASS SVN Revision: 67528
Erstellungsdatum: 2016-01-10
Build Platform: i386-w64-mingw32
GDAL/OGR: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2
maybe the source path has to be updated accordingly to the build
environment?
thanks
[1]
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/mswindows
/GRASS-Packager.bat.tmpl#L61
Ticket URL: <https://trac.osgeo.org/grass/ticket/2861&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: MSWindows 7
Comment (by martinl):
Hopefully fixed in r67543 (trunk). Could you test the next builds of 7.1
(2016/01/11)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2861#comment:1&gt;
Comment (by hellik):
Replying to [comment:1 martinl]:
(2016/01/11)?
tested with WinGRASS-7.1.svn-r67543-201-Setup-x86.exe. the files are there
now.
it should be backported.
thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/2861#comment:2&gt;
Replying to [comment:2 hellik]:
done in r67549. After testing next (2016/01/12) 703svn build (1,2) can be
the ticket closed.
(1) https://wingrass.fsv.cvut.cz/x86_64/grass70/
(2) https://wingrass.fsv.cvut.cz/x86/grass70/
Ticket URL: <https://trac.osgeo.org/grass/ticket/2861#comment:3&gt;
Replying to [comment:3 martinl]:
be the ticket closed.
seems to be OK, can you confirm it?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2861#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:4 martinl]:
confirmed.
thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/2861#comment:5&gt;
