#2862: v.dissolve not working
Reporter: AAHG | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Vector | Version: svn-releasebranch70
Keywords: v.dissolve | CPU: x86-64
Platform: MSWindows 7 |
I have pasted an example of the command and the error message below. It
happens when used through qgis and also from the command line.
''"'""' is not recognized as an internal or external command operable
program or batch file."''
Resolution: | Keywords: v.dissolve
CPU: x86-64 | Platform: MSWindows 7
Comment (by mlennert):
Replying to [ticket:2862 AAHG]:
You mean from the GRASS command line, i.e. without going through QGIS ?
Could you please provide a reproducible example, ideally using the North
Carolina demo data set ? 'tmp1452500056273' is not really something we can
work with.
