#2864: Add link to source code in the documentation pages.
Reporter: pmav99 | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.3
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
I don't know how easy it is to implement this, but I think that it would
be really helpful if the online documentation had links to the source
code.
Priority: normal | Milestone: 7.0.4
Component: Docs | Version: svn-releasebranch70
Resolution: | Keywords: open science, access
Comment (by lucadelu):
Replying to [comment:1 wenzeslaus]:
> The documentations seems a better place but I can see a reason why they
decided for GUI (similarly to ''Modify Help Entry'' button).
> For start you can try to add it to the footer of the manual page. The
[source:grass/trunk/tools/mkhtml.py tools/mkhtml.py] is where it is
implemented.
Implemented in trunk r67561. Let me know if you like it and if I can
backport it.
Comment (by martinl):
Replying to [comment:2 lucadelu]:
backport it.
I would suggest to move 'Source code' item at the end of the line (after
'Full index').
Moreover this line contains index links (so something generic which
doesn't depend on the given module). From this POV 'source code' (linked
to the module) is strange creature here. On the other hand I don't have
better idea where to put it.
BTW, the commit contains several non-necessary changes (line indentation),
we should try to avoid them.
Replying to [comment:4 martinl]:
or something like (two lines)
Source code
Main index | Raster index | Topics index | Keywords index | Graphical
index | Full index
backport it.
'Full index').
I also don't like the place, I would like to see it in the SEE ALSO
paragraph or something similar but it is to much work. Maybe the two lines
is better
indentation), we should try to avoid them.
yes we should avoid to leave empty lines with spaces and start to follow
PEPs
Should I first commit only the cleanup and after also the changes in the
code?
My editor, correctly, is removing spaces in blank lines automatically.
Replying to [comment:6 lucadelu]:
PEPs
code?
Comment (by pmav99):
Thank you all,
As far as I am concerned, the two lines seems cleaner to me. Now with
regard to the link itself.
1. I am not sure if hard-coding the link to trunk is the best option.
Since the documentation of multiple GRASS versions are online (i.e. 6.4,
7.0, 7.1) I think that the link should point to the respective branch.
2. Since I guess that many users like myself don't have any particular
knowledge of the GRASS code structure, in order to make this even more
useful I think that the links themselves should directly point to the
directory that contains the command in question.
I think that these two goals are not too hard to be achieved. E.g.
assuming that we know on which branch we are something like this would
give as a dictionary mapping each command to the correct link (you need to
execute it from the repository's root directory.
import os, fnmatch, urlparse
grass_command_paths = {}
grass_command_pattern = r'[a-zA-Z0-9]*.[a-zA-Z0-9]*'
for root, dirs, files in os.walk(grass_base_dir):
for name in dirs:
if fnmatch.fnmatch(name, grass_command_pattern):
grass_command_paths[name] = urlparse.urljoin(base_url,
os.path.join(root, name))
from pprint import pprint
pprint(grass_command_paths)
Mind you that there are a few false positives, but they should not be a
problem since `pgm` in
`mkhtml.py` will not match them. Of course, making the regex stricter is
always possible.
Replying to [comment:8 pmav99]:
> Thank you all,
It is hard-coded only because the idea is to have a url for each version.
there is a variable and it is changed only once. Using the dictionary
mapping it is more or less the same, when a new version will come it
should be added to the dictionary.
With only a variable there is less code and it should be a little bit
faster.
Comment (by wenzeslaus):
Replying to [comment:10 pmav99]:
> > If I understand correctly it is already like that.
> I am afraid that it does not work for the `scripts` commands.
`scripts` dir is one exception. Another are C modules living in the same
directory because they share a lot of code. Now I can think of `r3mapcalc`
and `r3.colors`.
We should definitively wait with backport before all these issues are
resolved. I almost changed the milestone to 7.1 instead of 7.0.4.
Replying to [comment:11 wenzeslaus]:
and `r3.colors`. Addons are of course yet another challenge.
`scripts` should be solved in r67565 and r67566.
I was already thinking to Addons, I'll investigate next days.
Do we have a list of modules like `r3.mapcalc` and `r3.colors`?
I don't know probably it is not so much work, I should be able to fix it
before 7.0.4.
I am afraid that this still does not work with scripts like those in
`raster/r.li/r.li.*` and `imagery/i.ortho.photo/i.ortho.*`. Anyway,
instead of adding special cases all over the place, wouldn't a single
function be a cleaner solution?
This should also work with addons (at least I don't see why it wouldn't).
Efficiency is not really relevant in documentation generation code and
even if it is it should be addressed as a separate issue (get it working
first, fast later).
import os
import urlparse
def get_source_code_url(pgm, base_url, root_path):
Return a url to the source code of `pgm`.
If the link cannot be constructed, return the url to the repo's root
directory.
Parameters
pgm: str
The name of the GRASS command.
base_url: str
The base url of the online source code browser.
root_path: str
The relative path to repository's root directory.
url = base_url
for root, dirs, files in os.walk(root_path):
for name in dirs:
if name == pgm:
pgm_path = os.path.join(root, name)
url = urlparse.urljoin(base_url, pgm_path)
return url
return url
Replying to [comment:13 pmav99]:
Should be done with r67578, I didn't use your function and I did something
really simple and it should work for every module.
For addons how it work the compilation of documentation?
Comment (by neteler):
'Full index').
> On the other hand I don't have better idea where to put it.
Suggestion: For now we put it *above* the footer line. It could even have
a <h2>SOURCE CODE</h2> entry there. It is then still below the "Last
changed" line but at least associated to the respective module text.
Replying to [comment:14 lucadelu]:
No problem, If I were you I would still put those lines in a function
though. No reason not to follow best practises. Anyway, thank you for your
efforts.
Priority: normal | Milestone: 7.0.5
Replying to [comment:15 neteler]:
... I still think that this would be definitely better.
Or: It could even have an own <h2>SOURCE CODE</h2> entry at page bottom
below "AUTHOR(S)".
Then it would be still below the "Last changed" line but at least visually
associated to the respective module text and show up in the TOC.
