#2867: Add modifier parameter to r.series
Reporter: pvanbosgeo | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.4
Component: Raster | Version: unspecified
Resolution: | Keywords: r.series
Comment (by mlennert):
Replying to [comment:2 glynn]:
> Replying to [ticket:2867 pvanbosgeo]:
> > An useful enhancement of r.series would be to add a "modifier" (or
similar name) parameter to r.series
> > which would allow to calculate the statistic defined by "method" on a
modified version of the maps (e.g. squared, square root, log, sin, cos,
etc.).
> My main concern is that this is going to open the door to a never-ending
stream of requests to add more modifiers or more features (e.g. parametric
modifiers, or selecting modifiers on a per-output bases) until we end up
having to embed either r.mapcalc or Python into r.series.
> OTOH, I'm aware that the usual solution (use in conjunction with
r.mapcalc) has a significant overhead when you're potentially dealing with
hundreds of input maps. Even so, I'd be inclined to limit the available
modifiers to those which seem likely to be particularly useful (only
sqrt/x^2 and log/exp spring to mind);
+1
> As for the patch itself, I'd suggest:
> 1. Determining the function during initialisation and setting a function
pointer, rather than performing the test in the inner loop. Multiple
strcmp()s inside a triple-nested loop (rows*columns*inputs) are likely to
add significant overhead.
+1
That's why I said in the mail accompanying the patch:
"Try the attached patch, which is just a brute-force, proof-of-concept.
It would be nicer to solve this with function pointers, but I'm not at
ease with that, so I'll leave that to others."
> 2. Vectorising the operations so that the dispatch is only done once per
row, not per value. Even an indirect call via a function pointer may be
more expensive than the function itself (some math functions may compile
to a single FPU instruction). The simplest way to do this would be to
modify inputs.buf in-place after reading.
> In that regard, maybe we should try to extract the relevant portions of
r.mapcalc to a separate library so that they can be re-used here?
If that is not too much work, then this would probably be a good thing.
But if it's only for adding a few modifiers to r.series is it worth the
effort ?
> Or maybe a better option would be to just package up the raster-I/O
loops as a Python module so that the actual processing can be implemented
as Python functions which convert a 2D (inputs*columns) array into a set
of 1D arrays (one per output).
You've lost me there.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2867#comment:3>
