[GRASS-dev] [GRASS GIS] #287: vdigit: don't force 'cat' as the key column name
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
r33285
When a new vector map is created in vdigit, it forces 'cat' as the key
column name. This is not really bad, and very common in other GRASS
modules, but I think it should be possible to specify a custom key column
name in any module that creates a vector map with a linked table.
Ticket URL: <http://trac.osgeo.org/grass/ticket/287&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
You can change default key column in GUI Preferences ("Attributes" tab).
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:1&gt;
Component: default | Version: svn-develbranch6
Changes (by msieczka):
  * component: wxGUI => default
Comment:
Replying to [comment:1 martinl]:
Cool, but that's not the same thing. I mean, that, ideally, the key column
setting should be adjustable ad command run time, too (this issue is not
limited to vdigit actually).
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:2&gt;
Comment (by martinl):
Replying to [comment:2 msieczka]:
column setting should be adjustable ad command run time, too (this issue
is not limited to vdigit actually).
Not only vdigit, also creating vector map layer from main menu
('Vector->Develop vector map->Create new vector map').
Do you mean to use GIS/environment variable like GRASS_KEY_COLUMN ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:3&gt;
Comment (by msieczka):
Replying to [comment:3 martinl]:
I know.
Oh, it would be usefull for sure, but that's not exactly what I meant. I
meant that each command that creates a vector map with a linked table
should allow for specifying the key column name at it's runtime. Having
such functionality *and* a global variable for a default, would be
optimal.
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:4&gt;
Component: Default | Version: svn-develbranch6
      Cpu: All |
Comment(by martinl):
Replying to [comment:4 msieczka]:
optimal.
Try r48512 (trunk) or r48513 (devbr6).
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:5&gt;
Priority: minor | Milestone: 6.4.3
      Cpu: All |
  * milestone: 6.4.0 => 6.4.3
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:6&gt;
      Cpu: All |
Replying to [comment:5 martinl]:
I meant that each command that creates a vector map with a linked table
optimal.
Note that it affects only creating new vector maps dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:8&gt;
