[GRASS-dev] [GRASS GIS] #2873: Simplify usage of GRASS in Python from outside
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Keywords: startup, installation, scripts, | CPU: Unspecified
  interpreter, windows installer, pygrass, |
  temporal, bootstrap, boilerplate |
Platform: All |
To use GRASS GIS functionality in Python from outside of a GRASS session,
i.e. without starting GRASS GIS explicitly and running a script (or an
actual module) in the session, one needs to include approximately 50 lines
as described in the
[https://grass.osgeo.org/grass70/manuals/libpython/script.html#module-
script.setup grass.script.setup] manual (or in the lengthy related
[https://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
wiki page]).
Ideally, one would just do import and then one or two lines of
initialization, for example:
#!python
import grass.script as gscript
rcfile = gscript.init_data("~/grassdata", "nc_spm", "user1")
do_what_ever_with_grass()
os.remove(rcfile)
== Suggestion ==
The attached code is a prototype implementation of the Python part which
would allow something like this. The code can only work if the following
variables are set:
#!bash
export GRASS_EXECUTABLE="/path/to/grass"
export LD_LIBRARY_PATH=$($GRASS_EXECUTABLE --config path)/lib
export PYTHONPATH=$($GRASS_EXECUTABLE --config path)/etc/python
The `GRASS_EXECUTABLE` does not have to be set if `grass` is on the path
or, in theory, if it is in on some standard path (e.g. `C:\Program Files
(x86)\GRASS GIS 7.0.0\grass70.bat` on MS Windows). However, dynamic
library path must always be set ahead (as described in #2424) for ctypes
to work (both PyGRASS and temporal depends on ctypes). The path to Python
packages must be set ahead as well if you want to use the initialization
functions from the package.
== Making it simple ==
The three lines above might be good enough on Linux where you just dump it
to command line or `.bashrc` but for MS Windows users it is too
complicated. The QGIS project also considers this too much work
([https://github.com/qgis/qgis3.0_api/issues/9 PyQGIS bootstrap is
complicated]).
GRASS Python packages could go to the system packages directory, so that
we avoid the need for setting `PYTHONPATH`. This might work well on MS
Windows when usage of system Python is implemented as described in #2333.
On Linux, `LD_LIBRARY_PATH` can be avoided if the libraries are installed
into the system path. On MS Windows, putting more things on `PATH` is
standard procedure from what I have seen. Mac OS X, `DYLD_LIBRARY_PATH`
can't be used anyway [https://lists.osgeo.org/pipermail/grass-
dev/2016-January/078531.html since El Capitan].
GRASS GIS executable should be on path on all platforms in the same way as
it is on path in Linux. This is maybe not standard on MS Windows but at
the end this is what users want (they want GRASS to be available right
away).
== Challenges ==
When putting dynamic libraries and Python packages directly into system
paths, installing more than one GRASS version becomes more complicated.
However, that's OK because only advanced users would have more than one
version, so the hard work of making it work (perhaps just not using the
default settings in the installer) will be on them. Beginners will likely
have just one version. The exception might be on MS Windows where it is
possible that beginner has standalone GRASS GIS, the one from QGIS and one
from OSGeo4W.
GRASS Python packages are not prepared to be imported when `GISBASE` is
not set and may require even more. We would need to change the code to not
require anything from GRASS session at import time. So far, I needed to
add lazy initialization for the translate function (underscore) to be able
to import `grass.script.core` (patch attached).
There is already some duplication between `grass.script.setup` and
`grass.py` executable. To create a full session (e.g. Mapset locking) we
would need even more duplication. We could move some parts from `grass.py`
to `grass.script.setup` if we are sure that we can import the right
`grass.script.setup` during the initialization phase (we already rely on
in when creating a Location).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873&gt;
      Type: | Status: new
  enhancement |
Resolution: | Keywords: startup, installation, scripts,
                         | interpreter, windows installer, pygrass,
       CPU: | temporal, bootstrap, boilerplate
  Unspecified | Platform: All
Changes (by wenzeslaus):
* Attachment "lazy_gettext.patch" added.
Patch for the lazy initialization of the underscore function (does not
require GISBASE at import time)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2873&gt;
      Type: | Status: new
  enhancement |
* Attachment "run_grass.py" added.
First prototype of API for simplified GRASS startup of standalone scripts
      Type: | Status: new
  enhancement |
Comment (by hellik):
Replying to [ticket:2873 wenzeslaus]:
session, i.e. without starting GRASS GIS explicitly and running a script
(or an actual module) in the session, one needs to include approximately
50 lines as described in the
wiki page]).
> #!python
> os.remove(rcfile)
> == Suggestion ==
variables are set:
> #!bash
it to command line or `.bashrc` but for MS Windows users it is too
complicated]).
there is no ''system Python'' in windows. users always has to install
python manually systemwide, possibly interfering with other python
installations installed by other software.
installed into the system path. On MS Windows, putting more things on
`PATH` is standard procedure from what I have seen.
>Mac OS X, `DYLD_LIBRARY_PATH` can't be used anyway
[https://lists.osgeo.org/pipermail/grass-dev/2016-January/078531.html
since El Capitan].
as it is on path in Linux. This is maybe not standard on MS Windows but at
away).
IMHO it is not a good practice to put ''everything'' in ''%PATH%'' in
windows. ''poisoning'' %PATH% should be avoided IMHO.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:1&gt;
      Type: | Status: new
  enhancement |
Comment (by wenzeslaus):
Replying to [comment:1 hellik]:
that we avoid the need for setting `PYTHONPATH`. This might work well on
MS Windows when usage of system Python is implemented as described in
#2333.
By system Python I mostly mean what #2333 is talking about. Possible
interference is the inherent issue of Windows operating system. I'm OK
with including multiple options in the installer giving the choice to the
user (with the last option being "Don't know what to choose? Install
Ubuntu and let the package managers solve it for you." ;-).
> > On MS Windows, putting more things on `PATH` is standard procedure
from what I have seen...
way as it is on path in Linux. This is maybe not standard on MS Windows
but at the end this is what users want (they want GRASS to be available
right away).
I'm not sure if we can do it. Is there a another way how to set path to
dynamic libraries for a process (so that Python scripts using GRASS ctypes
work)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:2&gt;
      Type: | Status: new
  enhancement |
See also Glynn's comment in [comment:53:ticket:580 ticket 580] speaking
about "fixing the installation process to make GRASS 'sessions' an
optional feature".
Ticket URL: <http://trac.osgeo.org/grass/ticket/2873#comment:3&gt;
      Type: | Status: new
  enhancement |
* Attachment "lib_python_script_init_data.patch" added.
Second prototype of API for simplified GRASS startup of standalone scripts
as a patch for lib/python/script
      Type: | Status: new
  enhancement |
* Attachment "test_no_session.py" added.
Test code for thge second prototype of API
      Type: | Status: new
  enhancement |
I uploaded a second prototype of the API as a patch. Before executing the
code outside of GRASS GIS, the following is needed:
#!bash
export GRASS_EXECUTABLE="/path/to/grass" # if GRASS is not on path
The minimal script is:
#!python
import grass.script.setup as gsetup
session = gsetup.init_data("~/grassdata", "nc_spm", "user1")
# code goes here, e.g. gscript.run_command(...)
session.close()
The names and the overall API is not final, nor is the implementation and
it might be nicer to have one import instead two. However, I think the
basic structure is right. Please comment.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2873#comment:4&gt;
      Type: | Status: new
  enhancement |
Replying to [comment:4 wenzeslaus]:
> ...it might be nicer to have one import instead two.
On the other hand, separating the stuff into its own module might have
some advantages. The API could look like:
#!python
import grass.session as gsession
session = gsession.create_session("~/grassdata", "nc_spm", "user1")
session.close()
And in future perhaps allow:
#!python
session_a = gsession.create_session("~/grassdata", "nc_spm", "user1")
session_b = gsession.create_session("~/grassdata", "nc_spf", "PERMANENT")
session_a.run_command(...)
session_b.run_command(...)
session_b.close()
session_a.close()
Now uploading a third prototype which is in the separate package, you can
do something like:
#!python
session = gsession.init_data(location="test_xy", mapset="test1",
geostring='XY')
session.close()
Code is still messy and naming is not final but should work. Some
documentation provided. Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:5&gt;
      Type: | Status: new
  enhancement |
* Attachment "grass_session_package.patch" added.
Third prototype with a separate package, location creation functionality
and some documentation (patch for lib/python directory)
      Type: | Status: new
  enhancement |
Comment (by glynn):
IMHO, this "solution" is yet more duct tape on top of the existing heap.
Any real solution would start by simply deleting the GRASS startup script
then figuring out what needs to be done to make everything still work
without it.
It should not be necessary to "start" GRASS.
On Unix, GRASS modules and libraries should be installed in system
directories. Python packages should go in Python's site-packages
directory. Environment variables should be set in /etc/profile (or
whatever mechanism the distribution uses, e.g. /etc/profile.d).
On Windows, configuration settings should probably be stored in the
registry.
GISRC should have a system-wide default setting such as $(HOME)/.grass/rc.
Users who never need more than one session at a time can just use that
file always, changing the database, location or mapset with g.mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:6&gt;
      Type: | Status: new
  enhancement |
Comment (by pmav99):
I think that the scope of this proposal is very wide. IMHO importing
dynamic libraries in a cross platform way and providing an official API
are different issues.
WRT to providing an official API for working with GRASS Locations/Mapsets
I believe that the proper python idiom is to use a
[https://pymotw.com/2/contextlib/index.html#module-contextlib| context
manager]. In other words, the user should not have to do anything E.g.:
{{{#!python
import grass.some_namespace.GrassSession
with GrassSession("/path/to/gisdb/location/mapset"):
     # work with the specified Location/Mapset
This could be expanded to creating temporary Locations/Mapsets:
{{{#!python
# not cleaning up might make sense when you debug a script.
with GrassSession.temporary(cleanup=False):
     # create a temporary location/mapset and optionally clean up when
exiting the context
or even creating new locations/mapsets:
{{{#!python
with GrassSession.create_from_epsg(mapset_path, epsg):
     # create a new location/mapset
with GrassSession.create_from_geofile(mapset_path, geofile_path):
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:7&gt;
      Type: | Status: new
  enhancement |
Replying to [comment:6 glynn]:
path or, in theory, if it is in on some standard path
I'll try to prepare some patch without this workaround which will expect
`grass` executable, Python pakcages and libraries already on path. The API
is the easy part here I guess.
script then figuring out what needs to be done to make everything still
work without it.
Back when you suggested that in #580 it seemed strange to me, but now I
think it would be much better than the current situation.
I can see this working for dynamic libraries and Python packages and I
think this would be good enough for now, but how this would work for
modules? For example, I have 141 PCL tools installed (`pcl_*`) but we have
>500 modules plus addons which actually have to be on a separate site. It
would be good to get opinions from some packagers.
Anyway, dynamic libraries and Python packages in system paths are place to
start. Can the compile/install process be set to this now?
$(HOME)/.grass/rc. Users who never need more than one session at a time
can just use that file always, changing the database, location or mapset
with g.mapset.
For me this is different because it is related to the data being used and
I'm not so convinced about it in comparison to the need for ready to use
runtime environment. I often work in more then one Mapset and I actually
use Mapset locks to see where I have already open sessions. However, I can
see that for many users permanent connection to given Mapset plus a
additional sessions (GISRCs) upon request (starting GRASS application or
API in some special way) might work, although particular details matter a
lot here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:8&gt;
      Type: | Status: new
  enhancement |
  Priority: major | Milestone: 7.2.0
''Support for scripting GRASS GIS in Ruby''
([https://github.com/jgoizueta/grassgis github.com/jgoizueta/grassgis]) is
something to take some inspiration from when creating something like a
Session class:
#!ruby
GrassGis.session configuration do
   g.list 'vect'
   puts output # will print list of vector maps
end
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:10&gt;
      Type: | Status: new
  enhancement |
  Priority: major | Milestone: 7.3.0
Changes (by martinl):
* milestone: 7.2.0 => 7.3.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:11&gt;
      Type: | Status: new
  enhancement |
  Priority: major | Milestone: 7.4.2
Comment (by neteler):
Meanwhile `pip install grass-session` is available (source:
https://github.com/zarch/grass-session), can the ticket be closed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:15&gt;
      Type: | Status: closed
  enhancement |
Resolution: fixed | Keywords: startup, installation, scripts,
* status: new => closed
* resolution: => fixed
Comment:
Now we have `pip install grass-session` for Python (and `grass ... --exec`
in command line). New suggestions and requests would need to specify the
relation to these and their evaluation. A new ticket would be more
appropriate. Closing as fixed since there is `pip install grass-session`.
''Trac management: bash processor for Trac which worked at one point seems
to be missing now (Error: Failed to load processor bash)''
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:16&gt;
