#2886: v.import/r.import: UnicodeEncodeError when path contains special characters
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Default | Version: svn-trunk
Keywords: v.import r.import encoding | CPU: Unspecified
Platform: Unspecified |
Trying to importing a file that resides in a path with special characters
(accent in this case), I get the following errors.
In trunk:
> v.import
input=/home/mlennert/Données/ne_110m_admin_0_countries/ne_110m_admin_0_countries.shp
output=countries
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/scripts/v.import", line 284, in <module>
options, flags = grass.parser()
gnu/etc/python/grass/script/core.py", line 719, in parser
cmdline += [b'"' + encode(arg) + b'"' for arg in sys.argv[1:]]
gnu/etc/python/grass/script/utils.py", line 174, in encode
return string.encode(enc)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 25:
ordinal not in range(128)
In release70:
> v.import
output=countries
File "/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-pc-linux-
gnu/scripts/v.import", line 273, in <module>
sys.exit(main())
gnu/scripts/v.import", line 158, in main
f.write('GISDBASE: %s\n' % GISDBASE)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 29: ordinal not in range(128)
Replying to [ticket:2886 mlennert]:
characters (accent in this case), I get the following errors.
> In trunk:
> > v.import
output=countries
> In release70:
Correction: in release70 the below error is due to GISDBASE containing an
accent, not because of the file path. When GISDBASE does not contain an
accent, below import works, even if the path to the imported file contains
an accent.
> > v.import
output=countries
> sys.exit(main())
