[GRASS-dev] [GRASS GIS] #2888: r.external wizzard shows "projection mach: no" although location was created by one of the dataset
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: unspecified
Keywords: r.external | CPU: x86-64
Platform: MSWindows 7 |
tested with
System Info
GRASS version: 7.1.svn
GRASS SVN revision: 67699
Build date: 2016-01-29
Build platform: x86_64-w64-mingw32
GDAL: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
dataset is Landsat 8 scene
gdalinfo LC81920282015221LGN00_B1.TIF
Driver: GTiff/GeoTIFF
Files: LC81920282015221LGN00_B1.TIF
Size is 7651, 7771
Coordinate System is:
PROJCS["WGS 84 / UTM zone 32N",
     GEOGCS["WGS 84",
         DATUM["WGS_1984",
             SPHEROID["WGS 84",6378137,298.257223563,
                 AUTHORITY["EPSG","7030"]],
             AUTHORITY["EPSG","6326"]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433],
         AUTHORITY["EPSG","4326"]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",9],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AUTHORITY["EPSG","32632"]]
Origin = (623985.000000000000000,5217915.000000000000000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
   AREA_OR_POINT=Point
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 623985.000, 5217915.000) ( 10d38' 2.38"E, 47d 6'11.11"N)
Lower Left ( 623985.000, 4984785.000) ( 10d34'23.75"E, 45d 0'20.44"N)
Upper Right ( 853515.000, 5217915.000) ( 13d39' 7.40"E, 47d 1'12.57"N)
Lower Right ( 853515.000, 4984785.000) ( 13d28'47.22"E, 44d55'42.83"N)
Center ( 738750.000, 5101350.000) ( 12d 5' 5.02"E, 46d 1'26.68"N)
Band 1 Block=7651x1 Type=UInt16, ColorInterp=Gray
g.proj -p
-PROJ_INFO-------------------------------------------------
name : Universal Transverse Mercator
proj : utm
datum : wgs84
ellps : wgs84
zone : 32
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
location was created with location by ''read projection and datum terms
from a georeferenced file''.
it works in 7.0.3.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888&gt;
#2888: r.external wizzard shows "projection match: no" although location was
Resolution: | Keywords: r.external
       CPU: x86-64 | Platform: MSWindows 7
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888#comment:1&gt;
  Reporter: hellik | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* cc: grass-dev@… (added)
* status: new => assigned
* owner: grass-dev@… => martinl
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888#comment:2&gt;
  Priority: normal | Milestone: 7.2.0
Comment (by neteler):
The libproj/GDAL interface received important updates (see #2456).
Can you please try again?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888#comment:4&gt;
Comment (by hellik):
Replying to [comment:4 neteler]:
no chance to test yes as wxgui doesn't start (#3011)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888#comment:5&gt;
Does it work in 7.0.4?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888#comment:6&gt;
Replying to [comment:6 neteler]:
as mentioned in the original report:
>it works in 7.0.3.
tested in 7.0.4, it seems to work also there.
report is for GRASS version: 7.1.svn
Ticket URL: <http://trac.osgeo.org/grass/ticket/2888#comment:7&gt;
Can you please test with 7.2.svn?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888#comment:8&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: r.external
Changes (by hellik):
* status: assigned => closed
* resolution: => worksforme
Comment:
Replying to [comment:8 neteler]:
tested by winGRASS7.2.svn
closing ticket; worksforme.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888#comment:9&gt;
