[GRASS-dev] [GRASS GIS] #2899: d.histogram launched from map display toolbar doesn't work
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: wxGUI | Version: svn-trunk
Keywords: d.histogram | CPU: Unspecified
Platform: All |
Map display - Analyze map - Create histogram with d.histogram: window
appears but there is nothing rendered, no error. Running d.histogram from
GUI command line works.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899&gt;
Resolution: | Keywords: d.histogram, rendering
       CPU: Unspecified | Platform: All
Changes (by wenzeslaus):
* keywords: d.histogram => d.histogram, rendering
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:1&gt;
Comment (by neteler):
I wonder if we still want to keep this old histogram tool in the layer
manager menu
or just remove it from there? The currently two menu entries are a bit
confusing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:2&gt;
Comment (by wenzeslaus):
Replying to [comment:2 neteler]:
manager menu
confusing.
I actually prefer the d.histogram-based tool. It does not have the
potential for interactivity as the wxPython-based but it uses raster's
color table and fills the bars which the wxPython-based currently does
not. Also the tools supports more the CLI-Python-GUI convergence. However,
I agree that two histogram items are not ideal.
Also, I tested the older revisions and it seems that r65205 broke the
histogram (same as #2857).
BTW, the wxPython-based histogram currently does not work for me with
wxPython 3.0.2.0 (#2558).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:3&gt;
Comment (by mlennert):
Replying to [comment:3 wenzeslaus]:
manager menu
confusing.
not.
How difficult would it be to implement this in the wx version ? I agree
that this is a very nice feature, even though more generally I prefer the
new tool for its interactivity, but also, for example for the capacity to
show several histograms at once.
Yes. That is an important point. Would it be possible to isolate the wx
version as a g.gui.histogram tool and then allow directly drawing the
results without interaction (i.e. with GRASS_RENDER_IMMEDIATE=TRUE) ?
> However, I agree that two histogram items are not ideal.
As long as #2558, please do not remove d.histogram. It's been the only way
to do histograms for me for quite a while...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:4&gt;
  Priority: blocker | Milestone: 7.1.0
* priority: normal => blocker
* milestone: 7.0.4 => 7.1.0
Comment:
Replying to mlennert:
way to do histograms for me for quite a while...
There is also the histogram with legend, but since we apparently can't
rely on the wxPython one, I'm raising the priority of this one. The
fallback option would be to revert r65205 but it might not be possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:5&gt;
Replying to [comment:5 wenzeslaus]:
Does anyone have any idea where this issue comes from ? d.histogram's last
change dates from 16 months ago and I've used it successfully since, so
the issue is probably linked to some change in the wxgui, but what ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:6&gt;
Replying to [comment:6 mlennert]:
last change dates from 16 months ago and I've used it successfully since,
so the issue is probably linked to some change in the wxgui, but what ?
r65205, see the comments above or #2857. You can use something like `svn
update -r65204` to check it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:7&gt;
  Priority: blocker | Milestone: 7.2.0
Comment (by martinl):
In [changeset:"68905" 68905]:
#!CommitTicketReference repository="" revision="68905"
d.histogram launched from map display toolbar doesn't work (see #2899)
Ticket URL: </ticket/2899#comment:9>
      Type: defect | Status: closed
Resolution: fixed | Keywords: d.histogram, rendering
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"68906" 68906]:
#!CommitTicketReference repository="" revision="68906"
d.histogram launched from map display toolbar doesn't work (fixes #2899)
(merge r68905 from trunk)
Ticket URL: </ticket/2899#comment:10>
Tested both in trunk and 7.2 on Linux. Thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2899#comment:11&gt;
