[GRASS-dev] [GRASS GIS] #29: moving of vector object by mouse
Reporter: zanollim | Owner: grass-dev@lists.osgeo.org
Priority: major | Milestone: 6.4.0
Component: Python | Version: svn-trunk
Keywords: |
when moving a vector object by mouse, the object isn't exactly below the
pointer (especially moving points) and when I click on the new position,
the object isn't placed correctly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/29&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
  Reporter: zanollim | Owner: martinl
      Type: enhancement | Status: assigned
Resolution: | Keywords: wxgui, digitization
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:2&gt;
Comment (by zanollim):
Now I click on the 'Move feature(s)' tool and[[BR]]
when I try to select a feature with the mouse,[[BR]]
I see this error and the feature isn't selected:
   File "/usr/src/grass_trunk/dist.i686-pc-linux-
gnu/etc/wx/gui_modules/mapdisp.py", line 818, in MouseActions
     self.OnLeftUp(event)
gnu/etc/wx/gui_modules/mapdisp.py", line 1214, in OnLeftUp
     digitClass.GetSelectType())
gnu/etc/wx/gui_modules/digit.py", line 1161, in SelectLinesByBox
     nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 *
vdigit.PORT_DOUBLE_MAX,
AttributeError: 'module' object has no attribute 'PORT_DOUBLE_MAX'
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:3&gt;
Comment (by martinl):
Replying to [comment:3 zanollim]:
You need to recompile vdigit interface since it has been changed (r29940).
cd gui/wxpython/vdigit
make
Restart GUI, then it should work.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:4&gt;
Replying to [comment:4 martinl]:
(r29940).
> make
sorry, it should be
make clean
make
You need to recompile it from scratch since some fn prototypes has been
changed too.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:5&gt;
Replying to [comment:5 martinl]:
> sorry, it should be
> make clean
> make
changed too.
> Martin
OK, but now, when compiling vdigit, i see this error:
grass6_wxvdigit_wrap.cxx:1883: error: no type named \u2018category\u2019
in \u2018struct swig::traits<std::pair<int, std::vector<int,
std::allocator<int> > > >\u2019
make: *** [OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o] Error 1
and the component isn't compiled.
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:6&gt;
Replying to [comment:6 zanollim]:
> > sorry, it should be
> > make clean
> > make
been changed too.
> > Martin
there are also changes in Makefile (still not stable, sorry). You need to
regenerate the Makefile.
make clean
cd ../../..
./configure (or configure.sh if you have own script)
make
Hope now it will work.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:7&gt;
Replying to [comment:7 martinl]:
to regenerate the Makefile.
> make clean
> cd ../../..
> make
> Martin
Sorry Martin,
after the ./configure (terminated with no errors)
when I run make the new error is:
make: shared: Command not found
make: [grass6_wxvdigit.so] Error 127 (ignored)
in the Makefile, inside the 'vdigit' folder, I read only this line with
the word 'shared':
LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) $(VECTLIB) $(GISLIB) $(GDALLIBS)
$(VEDITLIB) -lgdi $(WXLDFLAGS)
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:8&gt;
Replying to [comment:8 zanollim]:
the word 'shared':
Since this issue is not related to the bug, you can write me personally. I
assume you run ./configure without any switches (from the error I can see
at least without --with-cxx). I remember I prepared the script for
configuration on your machine. It is called configure.sh, you need to run
this script or ./configure with all needed switches.
Regards, Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:9&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: wxgui, digitization
Changes (by zanollim):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Thanks Martin,
I confirm that this bug is fixed.
michele
Ticket URL: <http://trac.osgeo.org/grass/ticket/29#comment:10&gt;
