#2909: g.gui.gmodeler - all layers rewritten by last output for more than one
parameter
Reporter: lfurtkevicova | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Default | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
when more than one "v.import" modules are used and all of input data are
set as parameter, outputs are the same (as the last of outputs)
parameter
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: gmodeler
Comment (by martinl):
This issue should be solved in r68050, the page names also contain item
id. This means that two `v.import` modules are now split into two pages.
parameter
