[GRASS-dev] [GRASS GIS] #291: font settings not saved
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: All
      Cpu: All |
1. enter Preferences > Display > Set font
2. choose e.g. Arial
3. Save
4. quit and restart wxGUI
5. use e.g. scalebar - your font setting was not saved as you see
Also, I don't how to change encoding in Preferences > Display > Set font.
Anything I enter instead of the default "ISO-8859-1" is discarded next
time I enter the dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/291&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
  * version: unspecified => svn-develbranch6
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Fixed in r33299.
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:1&gt;
Comment (by glynn):
Replying to [ticket:291 msieczka]:
font. Anything I enter instead of the default "ISO-8859-1" is discarded
next time I enter the dialog.
The font encoding needs to be set to whatever Python uses when passing
strings to the OS. This will probably be the locale's encoding unless it
explicitly uses something else. Also, the encoding only affects FreeType
fonts; stroke fonts are essentially ASCII.
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:2&gt;
Comment (by msieczka):
Replying to [comment:2 glynn]:
On my system encoding is pl_PL.UTF-8. Should I set the encoding in
Preferences > Display > Set font be set to that, instead of ISO-8859-1?
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 msieczka]:
"pl_PL.UTF-8" is the locale; the encoding is just "UTF-8".
> Should I set the encoding in Preferences > Display > Set font be set to
Probably. Try using some non-ASCII characters in e.g. d.text text="..."
and see what works.
If you have a Unicode version of wxWidgets, it's likely to use Unicode
internally (e.g. for anything you type into a text field). That will get
converted to a byte string (either by wxWidgets or by Python) by the time
that it's passed to d.text, and it will probably use the locale's encoding
to perform the conversion.
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:4&gt;
Replying to [comment:4 glynn]:
and see what works.
Whatever encoding I specify, e.g. ISO-8859-1 or UTF-8, Polish non-ASCII
chars are always rendered correct. I'm not sure if this is normal - when I
specify ISO-8859-1 I'd expect those chars to be rendered wrong.
As for the original bug report, it is fixed. Remaining issues:
1. The text overlay dialog is missing a show/hide checkbox.
2. If multiple labels are added, dragging them with a *right* mouse key
does some strange swapping.
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by cmbarton):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Fixed in r35121 (develbranch_6), r35122 (release branch 6.4), and r35123
(trunk)
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:6&gt;
