[GRASS-dev] [GRASS GIS] #2916: configure bug (?): FORTIFY_SOURCE in CPPFLAGS breaks configure on Arch Linux
Linux
Reporter: msieczka | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Keywords: | CPU: All
Platform: Linux |
Arch Linux build system by default sets CPPFLAGS="-D_FORTIFY_SOURCE=2".
If I unset FORTIFY_SOURCE, configure and make passes. But when it's set,
configure in GRASS 6 and 7 fails.
I'm attaching config.log-fail (FORTIFY_SOURCE is set) and config.log-pass
(FORTIFY_SOURCE is NOT set) for GRASS 7.0.3. The suspicious bits config
.log-fail seem to be:
/usr/include/sys/cdefs.h:30:3: error: #error "You need a ISO C conforming
compiler to use the glibc headers"
gcc: error: unrecognized command line option '-nologo'
gcc 5.3.0, make 4.1, autoconf 2.69
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916&gt;
Linux
Resolution: | Keywords:
       CPU: All | Platform: Linux
Changes (by msieczka):
* Attachment "config.log-fail" added.
Linux
* Attachment "config.log-pass" added.
Linux
Comment (by scimmia):
Known issue with the ancient version of autoconf used to generate the
configure script.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:1&gt;
Linux
Comment (by neteler):
Replying to [ticket:2916 msieczka]:
You would need to use autoconf-2.13 if you want to regenerate the
configure script. But I guess you don't do that anyway.
I tried on my Fedora box:
Copying config.status to config.status.x86_64-pc-linux-gnu
GRASS is now configured for: x86_64-pc-linux-gnu
   Source directory: /home/neteler/software/grass71
   Build directory: /home/neteler/software/grass71
   Installation directory: ${prefix}/grass-7.1.svn
   Startup script in directory:${exec_prefix}/bin
   C compiler: gcc -O2 -march=native -fdiagnostics-color
   C++ compiler: c++ -O2 -D_FORTIFY_SOURCE=2
gcc --version
gcc (GCC) 5.3.1 20151207 (Red Hat 5.3.1-2)
I have a link which seems to be missing on your system according to your
log file:
ls -la /lib/cpp
lrwxrwxrwx 1 root root 10 Dec 8 18:45 /lib/cpp -> ../bin/cpp*
# its origin:
rpm -qf /lib/cpp
cpp-5.3.1-2.fc23.x86_64
Maybe you simply lost that link?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:2&gt;
Linux
Comment (by msieczka):
Replying to [comment:2 neteler]:
I'd rather rely on an upstream-provided configure script, if possible.
Is it OK that CPPFLAGS content ends up in CXXFLAGS?
log file:
> ls -la /lib/cpp
> # its origin:
> rpm -qf /lib/cpp
There is no CPP package as such on Arch Linux. cpp, gcc and g++
executables come in a single GCC package here. It doesn't provide this
`/lib/cpp' link.
Anyway, I created /lib/cpp -> ../bin/cpp symlink manually, but this
doesn't help and doesn't seem to be the actual issue. The references to a
missing /lib/cpp link only got replaced by yet more "_FORTIFY_SOURCE
requires compiling with optimization" warnings. The original errors
remain:
I'm attaching a complete config.log-fail-with_cpp_symlink.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:3&gt;
Linux
* Attachment "config.log-fail-with_cpp_symlink" added.
Linux
I have regenerated the configure script with autoconf-2.13 now. No
improvement: configure still fails when CPPFLAGS="-D_FORTIFY_SOURCE=2" is
set, and the resulting config.log is pretty much identical to the attached
config.log-fail​.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:4&gt;
Linux
Replying to [comment:4 msieczka]:
Why do you do this? there is no need for that, all is in SVN.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:5&gt;
Linux
Replying to [comment:3 msieczka]:
SVN-grass is upstream.
I see.
> It doesn't provide this `/lib/cpp' link.
Seems to be a known issue in Archlinux, e.g.:
https://bbs.archlinux.org/viewtopic.php?id=147199
Suggestion: Try to set CPP, then configure (guessing here):
export CPP=/usr/bin/cpp
configure ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:6&gt;
Linux
Comment (by glynn):
configure:2722: checking how to run the C preprocessor
configure:2741: gcc -E -D_FORTIFY_SOURCE=2 conftest.c >/dev/null
2>conftest.out
In file included from /usr/include/assert.h:35:0,
                  from configure:2736:
/usr/include/features.h:328:4: warning: #warning _FORTIFY_SOURCE requires
compiling with optimization (-O) [-Wcpp]
  # warning _FORTIFY_SOURCE requires compiling with optimization (-O)
configure: failed program was:
This all arises because autoconf tends to treat ANYTHING written to stderr
as indicating a failure.
It then goes on to try:
configure:2758: gcc -E -traditional-cpp -D_FORTIFY_SOURCE=2 conftest.c
>/dev/null 2>conftest.out
In file included from /usr/include/assert.h:36:0,
                  from configure:2754:
which fails for the same reason.
Finally it tries:
configure:2775: gcc -nologo -E -D_FORTIFY_SOURCE=2 conftest.c >/dev/null
2>conftest.out
After everything it has tried has failed (by its standards), it
unconditionally sets CPP to /lib/cpp and uses that (resulting in every
subsequent use of $(CPP) failing).
The first thing it tried (gcc -E) would actually work, but it doesn't know
that.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:7&gt;
Linux
Replying to [comment:5 neteler]:
I thought I'd try this after your #comment:2, quote:
  "You would need to use autoconf-2.13 if you want to regenerate the
configure script. But I guess you don't do that anyway."
Nevermind.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:8&gt;
Linux
Replying to [comment:6 neteler]:
I'm talking from Arch Linux package perspective. In that case "upstream"
is GRASS 7.0.3 source code tarball.
> I see.
> configure ...
Thanks. This doesn't change anything though.
I think Glynn nailed it. I'm going to have a closer look at his comments
now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:9&gt;
Linux
Replying to [comment:7 glynn]:
set, configure in GRASS 6 and 7 fails.
2>conftest.out
requires compiling with optimization (-O) [-Wcpp]
stderr as indicating a failure.
Thanks for the explanation. Do you know why this "_FORTIFY_SOURCE requires
compiling with optimization (-O)" warning is triggered? I think it
shouldn't be, because I do have optimization enabled in my build
environment:
$ grep '\-O' /etc/makepkg.conf
CFLAGS="-march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong"
CXXFLAGS="-march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong"
LDFLAGS="-Wl,-O1,--sort-common,--as-needed,-z,relro"
config.log-fail contents also reflect this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:10&gt;
Linux
Comment (by glynn):
Replying to [comment:10 msieczka]:
requires compiling with optimization (-O)" warning is triggered? I think
it shouldn't be, because I do have optimization enabled in my build
environment:
Optimisation switches are normally in CFLAGS or CXXFLAGS, while -D
switches are normally in CPPFLAGS. The configure checks for the
preprocessor don't pass $(CFLAGS) or $(CXXFLAGS) because most of the
switches that they're likely to contain often aren't recognised by a
standalone preprocessor, and may result in an error. The comment in
autoconf/c.m4 says:
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
Apart from that, there are valid reasons for compiling without
optimisation (e.g. it often makes debugging significantly more difficult),
so forcibly enabling _FORTIFY_SOURCE doesn't appear to have been a
particularly wise move.
FWIW, on Gentoo this is implemented within the compiler:
$ gcc -E -dM -O2 -x c /dev/null | fgrep FORTIFY
#define _FORTIFY_SOURCE ((defined __OPTIMIZE__ && __OPTIMIZE__ > 0) ? 2 :
0)
I.e. _FORTIFY_SOURCE is enabled automatically if and only if optimisation
is enabled.
As for workarounds, the simplest to implement would be to have
configure.in check whether $(CPPFLAGS) contains -D_FORTIFY_SOURCE and
either attempt to remove it or generate an error telling the user to
remove it. It can always be added to CFLAGS and/or CXXFLAGS.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2916#comment:11&gt;
Linux
I forgot to say that the /etc/makepkg.conf contents I quoted are as per
default Arch Linux settings, and that makepkg is an official build tool
for Arch packages. I'm saying this just to clarify that I'm not making
this case up, but that it's a real issue for Arch GRASS users, in case
anybody wondered.
So far I've been removing D_FORTIFY_SOURCE from CPPFLAGS before configure
as follows, in my Arch GRASS PKGBUILD (which is an input for makepkg,
something like a Gentoo ebuild):
CPPFLAGS=`echo $CPPFLAGS | sed 's/-D_FORTIFY_SOURCE=.//g'`
If understand what you are saying, the following would be better (putting
aside your point against forcibly enabling _FORTIFY_SOURCE at all):
export CFLAGS="$CPPFLAGS $CFLAGS"
export CXXFLAGS="$CPPFLAGS $CXXFLAGS"
unset CPPFLAGS
By "better" here I mean "preserving the intended makepkg environment at
GRASS build-time".
Do you know whether all (sane) CPPFLAGS can be safely be mixed into
CXXFLAGS and CFLAGS like this?
And what do you think about scimmia's "ancient version of autoconf used"
#comment:1? I mean could using a newer autoconf version to generate the
GRASS configure script fix the problem?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:12&gt;
Linux
Comment (by glynn):
Replying to [comment:12 msieczka]:
(putting aside your point against forcibly enabling _FORTIFY_SOURCE at
all):
unset CPPFLAGS
The problem with this is that it breaks any case where the preprocessor is
run standalone, rather than as part of compilation.
I don't think that happens anywhere within actual the GRASS build process,
as Platform.make.in doesn't mention @CPP@ anywhere (so there's no valid
way for a Makefile to know how to run the preprocessor by itself).
But it can create problems for the configure script, which uses the pre-
processor extensively. E.g. AC_CHECK_HEADERS is based upon AC_TRY_CPP, so
if it needs e.g. any -I switches from CPPFLAGS, moving those into
CFLAGS/CXXFLAGS will break it.
That isn't a problem. The C compiler is always passed both $(CFLAGS) and
$(CPPFLAGS), while the C++ compiler is always passed both $(CXXFLAGS) and
$(CPPFLAGS). If the preprocessor is run separately, it should only be
passed $(CPPFLAGS), hence the distinction.
Maybe. Like many autoconf macros, AC_PROG_CPP runs through a fixed set of
candidates until one appears to work. It's possible that a newer version
has more candidates. Or it's possible that it's smarter at ignoring
warnings from the preprocessor.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:13&gt;
Linux
Replying to [comment:13 glynn]:
How about this:
CFLAGS="$CPPFLAGS $CFLAGS" CXXFLAGS="$CPPFLAGS $CXXFLAGS" CPPFLAGS=`echo
$CPPFLAGS | sed 's/-D_FORTIFY_SOURCE=.//g'` ./configure
This way I'm passing all CPPFLAGS as declared in /etc/makepkg.conf to
CXXFLAGS and CFLAGS for make, I don't give up on CPPFLAGS entirely in case
it contained anything that configure could need, but I drop
D_FORTIFY_SOURCE from CPPFLAGS for configure, to avoid the
"_FORTIFY_SOURCE requires compiling with optimization" issue. Seems least
intrusive and foolproof?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:14&gt;
Linux
Comment (by glynn):
Replying to [comment:14 msieczka]:
> How about this:
It would be better if any _FORTIFY_SOURCE definition could be extracted
and moved into CFLAGS/CXXFLAGS, e.g.
FORTIFY_FLAGS=`echo "$CPPFLAGS" | sed
'/^.*\(-D_FORTIFY_SOURCE=.\).*$/s//\1/'`
CPPFLAGS=`echo "$CPPFLAGS" | sed 's/-D_FORTIFY_SOURCE=.//g'`
CFLAGS="$FORTIFY_FLAGS $CFLAGS"
CXXFLAGS="$FORTIFY_FLAGS $CXXFLAGS"
This avoids any potential problems with duplicating the other elements of
$CPPFLAGS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:15&gt;
Linux
Replying to [comment:15 glynn]:
Excellent. Thanks a ton.
In summary: there's nothing that GRASS should do about this issue, it's
down to the fact that D_FORTIFY_SOURCE should not go into CPPFLAGS, only
to CFLAGS and CXXFLAGS. Please let me know whether that's correct.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:16&gt;
