[GRASS-dev] [GRASS GIS] #2919: r.stream.extract error
Reporter: PitStop | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: 7.0.3
Keywords: r.stream.extract | CPU: x86-64
Platform: MSWindows 7 |
Hi There,
I'm trying to delineate a watershed and also extract the streams within
using here for reproduction the NC data set.
r.watershed elevation=elev_srtm_30m@PERMANENT threshold=1000
accumulation=accu drainage=drain basin=basin
and then
r.stream.extract elevation=elev_srtm_30m@PERMANENT accumulation=accu@user1
threshold=1000 stream_raster=stream_r stream_vector=stream_v
leads to
ERROR: Missing value for parameter <d8cut>
while the accumulation map is specified in the command and therefor d8cut
shouldn't be used.
The same error was report [http://osgeo-org.1560.x6.nabble.com/r-stream-
extract-grass7-addon-td5018389.html#a5018528]
g.version -g
version=7.0.3
date=2016
revision=67691
build_date=2016-01-28
build_platform=x86_64-w64-mingw32
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919&gt;
  Priority: normal | Milestone: 7.0.4
Resolution: | Keywords: r.stream.extract
       CPU: x86-64 | Platform: MSWindows 7
Changes (by neteler):
* milestone: => 7.0.4
Comment:
I just tried on Linux, no such issue:
g.region raster=elev_srtm_30m
No errors occured.
g.version -g
version=7.0.4svn
date=2016
revision=67880M
build_date=2016-01-20
build_platform=x86_64-pc-linux-gnu
You marked it as "addon" while it is part of core GRASS 7. Is it possible
that you are using a leftover Addon version of r.stream.extract?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:1&gt;
Comment (by hellik):
Replying to [comment:1 neteler]:
accumulation=accu@user1 \
> No errors occured.
> g.version -g
> version=7.0.4svn
> date=2016
> revision=67880M
possible that you are using a leftover Addon version of r.stream.extract?
Confirmed here in winGRASS. the default value of d8cut seems not to be
recognized by parser in winGRASS again. see the mentioned ML entry.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2919#comment:2&gt;
Comment (by neteler):
I see: the change r53993 (remove default: infinity) was not applied to
relbranch7, see
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/raster/r.stream.extract/main.c#L113
Seems that "infinity" is not understood by the parser?
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/raster/r.stream.extract/main.c#L195
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:3&gt;
  Priority: normal | Milestone: 7.0.6
Replying to [comment:3 neteler]:
relbranch7, see
still an issue in all g7-variants.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:6&gt;
#2919: Use SFD above this threshold - infinity doesn't work in r.stream.extract
  Priority: normal | Milestone: 7.2.3
Component: Addons | Version: svn-releasebranch72
Changes (by hellik):
* milestone: 7.0.6 => 7.2.3
* version: 7.0.3 => svn-releasebranch72
Comment:
changing title.
see also #3432
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:7&gt;
taken from #3432
still an issue in relbranch 7
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r71600
Build date: 2017-10-27
Build platform: x86_64-w64-mingw32
GDAL: 2.2.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
and trunk
System Info
GRASS version: 7.2.2
GRASS SVN revision: r71496
Build date: 2017-09-20
GDAL: 2.2.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:8&gt;
Component: Raster | Version: svn-releasebranch72
       CPU: x86-64 | Platform: MSWindows 8
* platform: MSWindows 7 => MSWindows 8
* component: Addons => Raster
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:9&gt;
relbranch7, see
yes, it seems to be a parser issue. but why it works then in linux?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:10&gt;
Comment (by marisn):
Replying to [comment:10 hellik]:
My guess - input.d8cut->answer contains extra chars (CR/LF issue?) and
thus changing line to read:
if (strncmp(input.d8cut->answer, "infinity", 8) == 0) {
would solve the issue. Still, if it is so, then it is worth to digg deeper
to see why it is failing as strcmp is used in many modules.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:11&gt;
Comment (by mmetz):
Replying to [comment:11 marisn]:
there can't be CR/LF, answers are terminated by '\0'
> and thus changing line to read:
The d8cut option is not required, therefore I removed the problematic
default answer "infinity" and changed
- if (strcmp(input.d8cut->answer, "infinity") == 0) {
+ if (!input.d8cut->answer) {
in trunk and relbr72 with r71607,8.
> Still, if it is so, then it is worth to digg deeper to see why it is
I guess that the MS Windows version of sscanf does not recognize infinity
as a floating point number, while the Linux version does.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:12&gt;
  Priority: normal | Milestone: 7.8.3
Component: Raster | Version: git-releasebranch78
* version: svn-releasebranch72 => git-releasebranch78
* milestone: 7.2.4 => 7.8.3
Comment:
The code is now here:
https://github.com/OSGeo/grass/blob/75ac17f0a3f19cbff749badaf0a46aa7d0f91537/raster/r.stream.extract/main.c#L107
Not sure what to look for?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:15&gt;
isn't it some kind of a parser issue?
as it pops up also in other modules/addons, e.g.
https://lists.osgeo.org/pipermail/grass-user/2020-June/081577.html
worth to open a GH issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:16&gt;
some background information:
https://sourceforge.net/p/mingw/bugs/2358/
  You are using Microsoft's implementation of scanf(), (because that is all
that MinGW has ever used for this function, and its siblings), so the
behaviour is as Microsoft have specified it, (and there appears to be
nothing in their documentation to suggest how infinities and nans might be
converted,
You may consider Microsoft's implementation to be broken -- and you may
well be right -- but good luck with trying to get them to acknowledge
that, much less fix it.
AFAIR there was also some discussion some times ago how winGRASS (not)
handling NaN in raster data. (can't find ticket or thread at the moment).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:17&gt;
