[GRASS-dev] [GRASS GIS] #2933: v.label issue
Reporter: vincent | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Linux |
v.label "where" option is broken. Depending on the sql statement provided
it results in a 0/1 filter (zero or all features labeled).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2933&gt;
Resolution: | Keywords: v.label
       CPU: Unspecified | Platform: Linux
Changes (by martinl):
* keywords: => v.label
Ticket URL: <https://trac.osgeo.org/grass/ticket/2933#comment:1&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.0.7
Resolution: wontfix | Keywords: v.label
* status: new => closed
* resolution: => wontfix
Comment:
No activity. No reproducable example.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2933#comment:5&gt;
Comment (by veroandreo):
Here's how to test in NC
v.label map=railroads@PERMANENT column=OBJECTID where="OBJECTID >= 10800"
labels=railroads
d.mon wx0
d.vect railroads
d.labels railroads
Seems to work fine, it does respect the where condition. I'd better close
as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2933#comment:6&gt;
Comment (by vincent):
You are right, now it works fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2933#comment:7&gt;
      Type: defect | Status: reopened
Changes (by veroandreo):
* status: closed => reopened
* resolution: wontfix =>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2933#comment:8&gt;
Resolution: fixed | Keywords: v.label
* status: reopened => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2933#comment:9&gt;
