#2935: r.watershed returns bogus flow direction without warning when using large
"virtual" terrain
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: 6.4.4
Keywords: | CPU: Unspecified
Platform: MacOSX |
I'm using the hydropotential, in units Pa, as my "elevation" for
r.watershed in order to route flow under a glacier. The values are larger
than a normal elevation, although perhaps not using grass for planetary
research. The output of "r.info" follows. When I use this with
{{{r.watershed -a --v elevation=phi accumulation=acch drainage=fdir
thresh=50 flow=RUh.2k}}}, the {{{fdir}}} results are incorrect.
If I {{{r.mapcalc 'phi = phi / 1000' # [Pa] to [kpa]}}}, then things
work.
I can provide example files if needed to recreate this.
> r.info phi
| Layer: phi Date: Wed Feb 24 20:37:58 2016
| Mapset: PERMANENT Login of Creator: mankoff
| DataBase: /Users/mankoff/data/grass
| Title: ( phi )
| Timestamp: none
| Type of Map: raster Number of Categories: 255
| Data Type: DCELL
| Rows: 538
| Columns: 301
| Total Cells: 161938
| Projection: Stereographic
| N: -657600 S: -3349500 Res: 5003.53159851
| E: 864700 W: -638000 Res: 4992.35880399
| Range of data: min = -250782 max = 32395007.4
| Data Description:
| generated by r.mapcalc
| Comments:
| 1000 * 9.8 * z_b + 917 * 9.8 * (z_s - z_b)
Now that grass supports other planets https://grasswiki.osgeo.org/wiki/Planetary_mapping it is likely others
will run into similar issues when flow routing over terrain with values
significantly larger than Earth topography.
