#2940: Compiling Grass-7.0.3 under FreeBSD: tplot directory (with log)
Reporter: pieside | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Default | Version: 7.0.3
Keywords: FreeBSD | CPU: x86-64
Platform: Other Unix |
Dear all,
I'm trying to compile Grass-7.0.3 under FreeBSD (with Zsh) and the
compilation stops in
include/Make/GuiScript.make:37: recipe for target 'g.gui.tplot.tmp.html'
failed
include/Make/GuiScript.make:23: recipe for target 'guiscript' failed
Here you can find the log created by running
cd grass-7.0.3/gui/wxpython/tplot &&
make
gmake /home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/docs/html/g.gui.tplot.html
gmake[1]: Entering directory
'/home/pierre/tmp/grass7/grass-7.0.3/gui/wxpython/tplot'
GISRC=/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/demolocation/.grassrc70
GISBASE=/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2 PATH="/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/bin:/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/scripts:$PATH"
PYTHONPATH="/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/etc/python:/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64
-unknown-freebsd10.2/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/scripts:/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64
-unknown-freebsd10.2/lib:/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64
-unknown-freebsd10.2/lib:" LC_ALL=C
freebsd10.2/scripts/g.gui.tplot --html-description < /dev/null | grep -v
'</body>\|</html>' > g.gui.tplot.tmp.html
File "/home/pierre/tmp/grass7/grass-7.0.3/dist.x86_64-unknown-
freebsd10.2/scripts/g.gui.tplot", line 131, in <module>
main()
freebsd10.2/scripts/g.gui.tplot", line 78, in main
options, flags = gscript.parser()
freebsd10.2/etc/python/grass/script/core.py", line 712, in parser
p = subprocess.Popen([prog, '-n'] + argv, stdout=subprocess.PIPE)
File "/usr/local/lib/python2.7/subprocess.py", line 710, in __init__
errread, errwrite)
File "/usr/local/lib/python2.7/subprocess.py", line 1335, in
_execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
../../../include/Make/GuiScript.make:37: recipe for target
'g.gui.tplot.tmp.html' failed
gmake[1]: *** [g.gui.tplot.tmp.html] Error 1
rm g.gui.tplot.tmp.html
gmake[1]: Leaving directory
../../../include/Make/GuiScript.make:23: recipe for target 'guiscript'
failed
gmake: *** [guiscript] Error 2
What do you think about all that?
Thank you,
Pierre.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2940>
