[GRASS-dev] [GRASS GIS] #2942: Startup after Novice Install
Reporter: pactriglo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Startup | Version: 7.0.3
Keywords: | CPU: OSX/Intel
Platform: MacOSX |
Last login: Sun Feb 28 19:57:43 on ttys000
BenjamiillosMBP:~ benjaminpezzillo$
'/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.10 found.
Starting GRASS GIS...
dyld: Library not loaded: /usr/local/lib/libintl.8.dylib
   Referenced from:
/Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.3.dylib
   Reason: image not found
   File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/gis_set.py", line
31, in <module>
     from core import globalvar
   File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/globalvar.py",
line 29, in <module>
     from core.debug import Debug
   File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/debug.py",
line 66, in <module>
     Debug = DebugMsg()
   File
line 37, in __init__
     self.SetLevel()
   File
line 42, in SetLevel
     self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
   File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
line 934, in gisenv
     s = read_command("g.gisenv", flags='n')
   File
line 442, in read_command
     process = pipe_command(*args, **kwargs)
   File
line 417, in pipe_command
     return start_command(*args, **kwargs)
   File
line 355, in start_command
     if debug_level() > 0:
   File
line 1517, in debug_level
     _debug_level = int(gisenv().get('DEBUG', 0))
   File
line 934, in gisenv
   File
line 445, in read_command
     return handle_errors(returncode, stdout, args, kwargs)
   File
line 312, in handle_errors
     returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n']
ended with error
Process ended with non-zero return code -5. See errors in the (error)
output.
Error in GUI startup. If necessary, please report this error to the GRASS
developers.
Switching to text mode now.
Hit RETURN to continue...
   File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 1438, in
<module>
     set_data()
   File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 681, in
set_data
     gui_startup(grass_gui == 'gtext')
   File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 703, in
gui_startup
     os.execlp(cmd_name, "-text")
   File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py",
line 329, in execlp
     execvp(file, args)
   File
line 346, in execvp
     _execvpe(file, args)
   File
line 382, in _execvpe
     func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942&gt;
  Priority: normal | Milestone: 7.0.6
Resolution: | Keywords:
       CPU: OSX/Intel | Platform: MacOSX
Description changed by neteler:
Old description:
  Referenced from:
  File
line 31, in <module>
  File
  File
    Debug = DebugMsg()
  File
    self.SetLevel()
  File
  File
line 934, in gisenv
  File
  File
  File
  File
  File
line 934, in gisenv
  File
  File
ended with error
output.
developers.
in <module>
    set_data()
set_data
gui_startup
  File
line 329, in execlp
    execvp(file, args)
  File
line 346, in execvp
  File
logout
Saving session...
...completed.
[Process completed]
New description:
   Referenced from:
   File
31, in <module>
   File
   File
     Debug = DebugMsg()
   File
     self.SetLevel()
   File
   File
line 934, in gisenv
   File
   File
   File
   File
   File
line 934, in gisenv
   File
   File
ended with error
output.
developers.
<module>
     set_data()
set_data
gui_startup
   File
line 329, in execlp
     execvp(file, args)
   File
line 346, in execvp
   File
logout
Saving session...
...completed.
[Process completed]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942#comment:3&gt;
Comment (by neteler):
The reason is probably a known problem with Mac's System Integrity
Protection.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942#comment:4&gt;
Comment (by annakrat):
Use homebrew from osgeo4mac:
brew tap osgeo/osgeo4mac
brew install grass7
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942#comment:5&gt;
brew install grass7
Is this the official recommendation on how to install GRASS GIS on Mac OSX these days ?
My students with MacOSX have been a bit confused about the different ways to download GRASS GIS, especially when they were trying to install it in parallel with QGIS for cross-usage (grass plugin and processing toolbox).
BTW, in the homebrew formula for grass7 [1] I see:
stable do
     url "https://grass.osgeo.org/grass72/source/grass-7.2.0.tar.gz&quot;
i.e. 7.2.0, instead of 7.2.1.
Maybe we should create a symbolic link
https://grass.osgeo.org/grass72/source/current_stable.tar.gz ->
https://grass.osgeo.org/grass72/source/grass-7.2.1.tar.gz
Or even
https://grass.osgeo.org/current_stable.tar.gz ->
to make it easier for build scripts such as these to always point to the latest stable version ?
Moritz
[1] https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/grass7.rb
On Tue, Jun 27, 2017 at 9:26 AM, Moritz Lennert
brew install grass7
I just got asked what this "brew thing" means... Is there a "GRASS GIS
brew in a nutshell" anywhere?
these days ?
stable do
Or even
We do have it for the snapshot which is script generated:
https://grass.osgeo.org/grass72/source/snapshot/grass-7.2.svn_src_snapshot_latest.tar.gz
but not yet for the stable releases which would require a manual
interaction by me on the server after a release.
OK, I have added that to the release procedure and have generated the link:
https://grass.osgeo.org/grass72/source/grass-7.2-latest.tar.gz
which points at time to the file "grass-7.2.1.tar.gz".
HTH,
Moritz
[1]
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
On Tue, Jun 27, 2017 at 3:26 AM, Moritz Lennert
brew install grass7
these days ?
I was recommending this way in our recent workshops because it's the
only way which works with SIP enabled. It's far from ideal because it
doesn't always work, sometimes people have several Python
installations on Mac which complicates things and for some reason,
ctypes don't work there (so no PyGRASS or digitizer or 3D view). And
the installation takes time on slower computers because it's compiling
everything.
Michael's binaries work only when SIP is disabled. It's fairly easy to
disable it, but still, you have to boot into recovery system, open
command line and run a command there, so it looks little scary for
most people.
Even your own compilation is fairly difficult, one reason is that
official wxPython 3 mac package is old and new macs refuse to open and
install. So in general I am getting sick of this issue and
unfortunately I don't have time nor knowledge to do anything about it.
this is something I haven't even tried. If some of your students find
better ways of installing GRASS, let me know.
Anna
stable do
Or even
Moritz
[1]
On Tue, Jun 27, 2017 at 2:32 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
brew install grass7
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942#comment:5>
these days ?
I was recommending this way in our recent workshops because it’s the
only way which works with SIP enabled. It’s far from ideal because it
doesn’t always work, sometimes people have several Python
ctypes don’t work there (so no PyGRASS or digitizer or 3D view). And
the installation takes time on slower computers because it’s compiling
everything.
Michael’s binaries work only when SIP is disabled. It’s fairly easy to
most people.
How much effort would it be to enable compatibility with the official wxPython 3 mac package? Maybe it is worth the effort?
GRASS tries hard to run on various different operating systems (alphabetically Android, BSD, Linux, Mac, Unix, Windows) and different versions of these.
Markus M
unfortunately I don’t have time nor knowledge to do anything about it.
this is something I haven’t even tried. If some of your students find
Anna
stable do
url “https://grass.osgeo.org/grass72/source/grass-7.2.0.tar.gz
Or even
Moritz
[1]
brew install grass7
these days ?
I have the system python, Python 2 (home-brew) and python-3 (also home-brew
install), and it installs without problems. Maybe because I have the hebrew
python install.
It usually get’s tricky if you are mixing different approaches of installing
programs (same on Linux). That is the reason why, where possible, am using
home-brew. I have, for example, no idea how home-brew / grass works together
with python installed via the apple way go MacPorts. This is something which
should be asked on the home-brew mailing list, or better, stackexchange.
also people have Anaconda these days. You have to be careful about the
order of Pythons in your PATH. (It sort of brings the actual meaning
of word python to my mind...)
Related to this, GRASS uses GRASS_PYTHON to force which Python is used.
and for some reason, ctypes don't work there (so no PyGRASS or digitizer or
3D view).
Never used them, but how can I test? Could you give me an example and I
could try on my machine.
Pretty simple, run any of the examples here:
https://grass.osgeo.org/grass73/manuals/libpython/pygrass_vector.html
The rest is to be tested in the GUI, digitizer and 3D view are
switched on in Map Display.
And the installation takes time on slower computers because it's compiling
everything.
Actually, there is a bottle (binary) available for grass 7 Sierra
09:02:43 ~$ brew info grass7
osgeo/osgeo4mac/grass7: stable 7.2.0 (bottled)
Geographic Resources Analysis Support System
http://grass.osgeo.org/
/usr/local/Cellar/grass7/7.2.0 (3,751 files, 69.6MB) *
  Poured from bottle on 2017-06-28 at 08:54:11
https://github.com/osgeo/homebrew-osgeo4mac/blob/master/Formula/grass7.rb
==> Dependencies
Build: pkg-config :heavy_check_mark:
Required: gettext :heavy_check_mark:, readline :heavy_check_mark:, flex :heavy_check_mark:, bison :heavy_check_mark:, lbzip2 :heavy_check_mark:, gdal2 :heavy_check_mark:, libtiff
:heavy_check_mark:, unixodbc :heavy_check_mark:, fftw :heavy_check_mark:, wxpython :heavy_check_mark:, cairo :heavy_check_mark:, ghostscript :heavy_check_mark:
Optional: openblas :heavy_check_mark:, liblas :heavy_check_mark:, netcdf :heavy_check_mark:, ffmpeg :heavy_check_mark:
==> Requirements
Required: unlinkedgrass7 ✘, python :heavy_check_mark:, numpy (python module) :heavy_check_mark:, x11 :heavy_check_mark:
Optional: postgresql :heavy_check_mark:, mysql :heavy_check_mark:
==> Options
--with-ffmpeg
Build with ffmpeg support
--with-gdal-1
Build with GDAL/OGR v1.x instead of v2.x
--with-liblas
Build with liblas support
--with-mysql
Build with mysql support
--with-netcdf
Build with netcdf support
--with-openblas
Build with openblas support
--with-postgresql
Build with postgresql support
--without-gui
Build without WxPython interface. Command line tools still available.
09:03:02 ~$
I just re-installed it. If you use non-default options, grass7 get’s usually
compiled - that is correct.
I see. On a recent workshop we did, a lot of people had problems with
installing GRASS with homebrew, and the most annoying part was that
they had all kinds of errors and we were able to figure out only some
of them.
most people.
Absolutely - It makes sense to have SIP, and I am not prepared to disable it
if I can avoid it - which I can by using homebrew.
You are running into the same problems as with the pre-build binaries from
Michael. I managed to get it to compile and run, but it was hackisch and not
all features worked - so no options. If you gave instructions once on this
mailing list but don’t have the mails at hand.
I used this:
https://stackoverflow.com/a/34622956/1058453
I haven't tried the new wxPython Phoenix on Mac yet.
As far as I know, you have to install both via home-brew (and if you are
mentioning the long compilation times of GRASS, start the compilation of
QGIS in home-brew in the evening! QGIS is beast to install via homebrew).
But: I haven’t used QGIS in a long time.
So to sum up:
1) mixed installs (Apple;e approach (.pkg, .dmg, Frameworks, …) combined
with home-brew, you likely will have problems.
2) grass 7 installs via home-brew from a binary on Sierra without
compilation
3) QGIS - grass under home-brew should work if both are installed under
home-brew, otherwise ask on the QGIS mailing list.
Thanks for any testing/advice. We should probably update official
instructions on the main website if we agree on what they should be.
Anna
Hope this helps,
Rainer
Anna
stable do
Or even
Moritz
[1]
Do you run this in GRASS session? Outside it won’t work.
Sorry, I meant Map Display toolbar. There is drop down widget to select digitizer and 3d view.
No, I should have, but most problems I encountered would be hard to reproduce anyway and I didn’t have access to their laptops. But the problem with ctypes should be reproducible.
This is wxpython 3, the new one is 4.
Sorry, I am traveling, so I can give only limited response.
Anna
brew install grass7
these days ?
python install.
of word python to my mind…)
I have the following python defined:
08:53:45 ~$ which python
/usr/local/bin/python
09:15:36 ~$ python --version
Python 2.7.13
09:15:43 ~$
which is the home-brew python.
GRASS 7.2.0 (grass):~ > echo $GRASS_PYTHON
python
[Raster MASK present]
GRASS 7.2.0 (grass):~ > which python
GRASS 7.2.0 (grass):~ > python --version
Python 2.7.13
and for some reason, ctypes don’t work there (so no PyGRASS or digitizer or
3D view).
OK - I am new to python (wrote my first lines of python code about two weeks ago…). So I am getting
importError: No module named grass.pygrass.vector
in a fresh python session.
I see the following in the Map Display menu - does this mean, that they are not working?
And the installation takes time on slower computers because it’s compiling
everything.
==> Dependencies
==> Requirements
==> Options
–with-ffmpeg
–with-gdal-1
–with-liblas
–with-mysql
–with-netcdf
–with-openblas
–with-postgresql
–without-gui
09:03:02 ~$
of them.
Interesting. Did you raise these with Larry Shaffer https://github.com/dakcarto who is maintaining the osgeo4mac tap?
I will try to setup a VirtualBox VM running Sierra and go through the complete install from the clean system. I will report back - please remind if you don’t hear anything.
most people.
I used this:
I haven’t tried the new wxPython Phoenix on Mac yet.
I have installed it from home-brew, if I am not completely mistaken:
$ pip2 search wx
wxPython-common (2.6.3.3) - Cross platform GUI toolkit for Python
INSTALLED: 3.0.2.0
LATEST: 2.6.3.3
and
9:32:24 ~/tmp$ brew info wxpython
wxpython: stable 3.0.2.0 (bottled)
Python bindings for wxWidgets
https://www.wxwidgets.org/
/usr/local/Cellar/wxpython/3.0.2.0 (992 files, 40MB) *
Poured from bottle on 2014-12-06 at 18:36:45
From: https://github.com/Homebrew/homebrew-core/blob/master/Formula/wxpython.rb
==> Dependencies
Required: wxmac :heavy_check_mark:
09:34:42 ~/tmp$ brew info wxmac
wxmac: stable 3.0.2 (bottled), devel 3.1.0, HEAD
Cross-platform C++ GUI toolkit (wxWidgets for macOS)
/usr/local/Cellar/wxmac/3.0.2_4 (810 files, 24.6MB) *
Poured from bottle on 2016-11-02 at 19:08:02
From: https://github.com/Homebrew/homebrew-core/blob/master/Formula/wxmac.rb
==> Dependencies
Required: jpeg :heavy_check_mark:, libpng :heavy_check_mark:, libtiff :heavy_check_mark:
==> Options
–with-static
build static libraries
–with-stl
use standard C++ classes for everything
–devel
Install development version 3.1.0
–HEAD
Install HEAD version
09:34:47 ~/tmp$
So to sum up:
  1. mixed installs (Apple;e approach (.pkg, .dmg, Frameworks, …) combined
  2. grass 7 installs via home-brew from a binary on Sierra without
    compilation
  3. QGIS - grass under home-brew should work if both are installed under
Yes - I am still wandering, why there is a SIP issue with a GIS program, but Michael and others explained it a few times here and definitively have a better understanding of this. Ih the long run, one should probably address this issue in the code base of GRASS so that installation via the official way is possible without hassles, but an approved / official installation procedure for using home-brew should be available.
Rainer
Anna
Hope this helps,
Rainer
Anna
stable do
Or even
Moritz
[1]
  Priority: normal | Milestone: 7.0.7
Comment (by martinl):
No activity. Feel free to re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942#comment:7&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords:
Changes (by martinl):
* status: new => closed
* resolution: => wontfix
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942#comment:8&gt;
