#2943: Absolute path in TGIS connection can make db inaccessible in a (mixed)
multi-user environment
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Temporal | Version: unspecified
Keywords: t.connect | CPU: Unspecified
Platform: Unspecified |
It seems that the connection to the TGIS sqlite.db is defined for the
mapset using an absolute paths.
That makes it inaccessible in cases where mount points change, e.g. in a
multi-user environment. In my particular case,
/grassdata/ETRS_33N/precipitation_daily/tgis/sqlite.db (produced from
within Linux) is (naturally) not readable from Windows where the
equivalent path would be
R:\grassdata\ETRS_33N\precipitation_daily\tgis\sqlite.db
One can work around this issue using t.connect -d when starting to work,
but this is only possible for "mapset owners".
Would be nice if environment variables could be used
($GISDBASE/$LOCATION_NAME/$MAPSET) and first expand/evaluate at access
time or relative path to the current mapset...
Priority: normal | Milestone: 7.0.5
Resolution: | Keywords: t.connect
Comment (by huhabla):
Replying to [ticket:2943 sbl]:
This issue should be solved in 7.2 release branch and trunk. The
connection should use relative paths to the tgis database as default.
However, be aware that the temporal framework was not tested on windows
and is not designed to run on windows systems.
