[GRASS-dev] [GRASS GIS] #2947: g.gui.gmodeler - not possible to remove data from model
Reporter: lfurtkevicova | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.4
Component: wxGUI | Version: svn-trunk
Keywords: g.region, gmodeler data deletion | CPU: x86-64
Platform: Linux |
It is not possible to delete data from model, e.g. I set region according
to vector layer ({{{g.region vector=area}}}). Then I change it and set
region according to raster({{{g.region raster=dmt}}}). Vector input is
still in model and it is not possible to remove it (also after reopening
{{{*.gxm}}} file).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2947&gt;
Resolution: | Keywords: g.region, gmodeler data deletion
       CPU: x86-64 | Platform: Linux
Comment (by lfurtkevicova):
Also it is the same when region is set according to raster layer and then
it is changed. Old settings are still displayed in model.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2947#comment:1&gt;
  Reporter: lfurtkevicova | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* status: new => assigned
* cc: grass-dev@… (added)
* type: enhancement => defect
* owner: grass-dev@… => martinl
Comment:
Should be fixed in r68155 (trunk). Please could you test it before
backporting?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2947#comment:2&gt;
Changes (by lfurtkevicova):
* Attachment "GRASS GIS Graphical Modeler_g_region.png" added.
In revision {{{68198}}} there is still bug, see attachment
Ticket URL: <https://trac.osgeo.org/grass/ticket/2947#comment:3&gt;
Comment (by martinl):
Replying to [comment:3 lfurtkevicova]:
Please send me the sample model and instruction what to do when
reproducing. Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2947#comment:4&gt;
Marking r68201 for backport
Ticket URL: <http://trac.osgeo.org/grass/ticket/2947#comment:5&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.0.5
Resolution: fixed | Keywords: g.region, gmodeler data deletion
* status: assigned => closed
* resolution: => fixed
Comment:
Backported to grass70 in r69161. Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2947#comment:7&gt;
