#2956: iostream compilation error: declaration of 'void* operator new (size_t)
throw (std::bad_alloc)' has a different exception specifier
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Keywords: iostream | CPU: All
Platform: Linux |
I'm trying to build GRASS GIS 7.0.3 for various Fedora/EPEL versions using
Fedora's COPR (chroot based compile environment).
The following error appears:
make[5]: Leaving directory
'/builddir/build/BUILD/grass-7.0.3/lib/python/imaging'
make[4]: Leaving directory '/builddir/build/BUILD/grass-7.0.3/lib/python'
make[3]: Leaving directory '/builddir/build/BUILD/grass-7.0.3/lib/python'
make[3]: Entering directory
'/builddir/build/BUILD/grass-7.0.3/lib/iostream'
test -d OBJ.x86_64-redhat-linux-gnu || mkdir -p OBJ.x86_64-redhat-linux-
gnu
c++ -O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2
-fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-
gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64
-mtune=generic -fPIC -I/builddir/build/BUILD/grass-7.0.3/dist.x86_64
-redhat-linux-gnu/include -I/builddir/build/BUILD/grass-7.0.3/dist.x86_64
-redhat-linux-gnu/include -DPACKAGE=\""grasslibs"\"
-I/builddir/build/BUILD/grass-7.0.3/dist.x86_64-redhat-linux-gnu/include
-DRELDIR=\"lib/iostream\" -o OBJ.x86_64-redhat-linux-gnu/mm_utils.o -c
mm_utils.cpp
-DRELDIR=\"lib/iostream\" -o OBJ.x86_64-redhat-linux-gnu/ami_stream.o -c
ami_stream.cpp
-DRELDIR=\"lib/iostream\" -o OBJ.x86_64-redhat-linux-gnu/mm.o -c mm.cpp
-DRELDIR=\"lib/iostream\" -o OBJ.x86_64-redhat-linux-gnu/rtimer.o -c
rtimer.cpp
mm.cpp: In function 'void* operator new (size_t)':
mm.cpp:279:7: error: declaration of 'void* operator new (size_t) throw
void* operator new (size_t sz) throw(std::bad_alloc) {
In file included from mm.cpp:49:0:
gnu/include/grass/iostream/mm.h:132:17: note: from previous declaration
'void* operator new (std::size_t)'
friend void * operator new(size_t) throw(std::bad_alloc);
mm.cpp: In function 'void* operator new(size_t)':
mm.cpp:330:7: error: declaration of 'void* operator new(size_t) throw
gnu/include/grass/iostream/mm.h:131:17: note: from previous declaration
'void* operator new(std::size_t)'
../../include/Make/Compile.make:35: recipe for target 'OBJ.x86_64-redhat-
linux-gnu/mm.o' failed
make[3]: *** [OBJ.x86_64-redhat-linux-gnu/mm.o] Error 1
It happens both on i386/i686 and x86_64.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2956>
