[GRASS-dev] [GRASS GIS] #2959: r.viewshed, r.terraflow and i.atcorr broken in 32/64bit builds
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Keywords: c++, r.viewshed, r.terraflow, | CPU: All
  i.atcorr, mingw64, mingw |
Platform: MSWindows 8 |
`r.viewshed`, `r.terraflow` and `i.atcorr` are not working in the new MS
Windows builds. These are C++ modules and does not work in 32bit and 64bit
versions.
The executable exists. The error message when running r.viewshed from the
system terminal is shown in a dialog:
The application was unable to start correctly (0xc000007b)
In relation to this message a [http://stackoverflow.com/questions/10492037
/the-application-was-unable-to-start-correctly-0xc000007b StackOverflow
posts] mentions `STATUS_INVALID_IMAGE_FORMAT` and 32-64 mismatch.
The issues were partially already reported in the following:
* [https://lists.osgeo.org/pipermail/grass-user/2016-February/073678.html
Error running r.viewshed in GRASS 7.0.3 on Windows 7]
* [http://gis.stackexchange.com/questions/179575/cannot-open-r-viewshed-
on-grass-7 Cannot open r.viewshed on Grass 7]
* [https://lists.osgeo.org/pipermail/grass-dev/2016-February/078842.html
C++ and libLAS modules broken in 7.0.3 in winGRASS]
* #2884
Applies to all variations:
* GRASS version: 7.1.svn (r67915, 2016-01-22), 7.0.3 (r67691, 2016-01-28)
* Build Platform: `x86_64-w64-mingw32` and `i386-w64-mingw32`
* Platform: `Windows-7-6.1.7601-SP1 (OSGeo4W)` and standalone
`Windows-8-6.2.9200`
Ticket URL: <https://trac.osgeo.org/grass/ticket/2959&gt;
Resolution: | Keywords: c++, r.viewshed, r.terraflow,
                         | i.atcorr, mingw64, mingw
       CPU: All | Platform: MSWindows 8
Comment (by hellik):
Replying to [ticket:2959 wenzeslaus]:
versions.
the system terminal is shown in a dialog:
[http://stackoverflow.com/questions/10492037/the-application-was-unable-
to-start-correctly-0xc000007b StackOverflow posts] mentions
user/2016-February/073678.html Error running r.viewshed in GRASS 7.0.3 on
Windows 7]
> * #2884
2016-01-28)
See also
https://trac.osgeo.org/grass/ticket/2884
Ticket URL: <https://trac.osgeo.org/grass/ticket/2959#comment:1&gt;
Changes (by annakrat):
* Attachment "error_viewshed.png" added.
error message
Comment (by annakrat):
I attached a message I get on Windows, perhaps might be helpful.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2959#comment:2&gt;
Comment (by martinl):
I added missing library to the builds in r68144 and r68145. Please check
tomorrow's build.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2959#comment:3&gt;
Comment (by wenzeslaus):
Replying to [comment:1 hellik]:
> See also
Off topic: Tickets on Trac can be linked using hash and number, e.g.:
`#2884`. The advantage is that Trac will tell you ticket title and status
in the tool tip and will strike out closed tickets. See for example the
original description of the ticket where I actually speak about `i.atcorr`
and link #2884. Also I don't see a need to quote the whole original
description. That's why we use Trac and not just mailing list for tracking
the issues. No need to read through description twice when I open the
ticket page.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2959#comment:4&gt;
Replying to [comment:3 martinl]:
tomorrow's build.
I have tested latest 7.0.4svn build and it seems to be fixed (I tested
`r.viewshed`). Please confirm.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2959#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: c++, r.viewshed, r.terraflow,
* status: new => closed
* resolution: => fixed
Comment:
Yes, it's working, thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2959#comment:6&gt;
