[GRASS-dev] [GRASS GIS] #296: d.barscale: can't use "none" for background color
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
According to d.barscale manual, bcolor can be 'a standard GRASS color,
R:G:B triplet, or "none"'. wxGUI dialog of the command doesn't allow for
"none".
Ticket URL: <http://trac.osgeo.org/grass/ticket/296&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
It's should be possible, see attached screenshot
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:1&gt;
Comment (by msieczka):
Replying to [comment:1 martinl]:
The bug has to do with translations.
d.barscale dialog is missing that "Transparent" checkbox when I run GRASS
built --with-nls in Polish locale.
If on GRASS terminal I do:
$ export LC_ALL=C
$ d.barscale
the dialog has the checkbox in place.
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:2&gt;
Comment (by martinl):
Replying to [comment:2 msieczka]:
GRASS built --with-nls in Polish locale.
> $ export LC_ALL=C
> $ d.barscale
Fix Polish translation to contain "none". This word shouldn't be
translated, it's keyword for option. Module cannot understand, e.g. in
Czech
d.barscale bcolor=průhledný
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:3&gt;
#296: wrong translations brake wxGUI
Component: default | Version: svn-develbranch6
Changes (by msieczka):
  * component: wxGUI => default
  * summary: d.barscale: can't use "none" for background color => wrong
Comment:
Replying to [comment:3 martinl]:
Czech
I see. I'm not going to get involved into translations any time soon. I'll
just change the subject and component. Thanks for looking into this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:4&gt;
  * status: assigned => new
  * owner: martinl => grass-dev@lists.osgeo.org
* cc: grass-dev@lists.osgeo.org (removed)
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:5&gt;
#296: wrong translations break wxGUI
Changes (by neteler):
  * summary: wrong translations brake wxGUI => wrong translations break
              wxGUI
Comment:
I have fixed the broken translation both in 6.4.svn and 7.0.trunk: r33313
and r33314.
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:6&gt;
Comment (by glynn):
Replying to [comment:4 msieczka]:
Let me guess: the GUI looks for the string "none" in the description? I
think that there should be a separate gisprompt setting for this case.
Even so, the description string shouldn't translate "none".
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:7&gt;
Replying to [comment:7 glynn]:
Yes it looks at label or description.
Currently is used
GISPROMPT_COLOR
i.e
"old,color,color"
Maybe we could use for enabling transparency
"old,color,none"
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:8&gt;
Comment (by glynn):
In 7.x, GRASS itself (i.e. libgis) only cares that there are three parts
(i.e. two commas), and whether or not the first part is "new" (which
affects whether an overwrite check is performed, and whether the
--overwrite option is shown).
In earlier versions, it's also used for terminal-based prompting, and must
have the form age,element,prompt. The age must be one of old, new, mapset,
any, old_file, new_file or color, and affects which G_ask_* function is
used to obtain input interactively from the terminal. The element part is
used to check whether the user's answer is valid, and to list available
options; it should be a valid element type.
IOW, GISPROMPT_COLOR should really be of the form color,?,?.
Beyond that, we need to give some thought to re-designing the type system.
The type, gisprompt, multiple, key_desc and options fields should all be
merged into a more flexible type system.
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:9&gt;
Replying to [comment:9 glynn]:
system. The type, gisprompt, multiple, key_desc and options fields should
all be merged into a more flexible type system.
I agree, see also #156.
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:10&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/296#comment:11&gt;
