[GRASS-dev] [GRASS GIS] #2960: db.login port parameter
Reporter: lucadelu | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.4
Component: Datasets | Version: svn-trunk
Keywords: database, postgresql, db.login | CPU: Unspecified
Platform: Unspecified |
It seems that PostgreSQL database library is not working correctly with
port different from the standard 5432.
Following the steps I did
db.connect driver=pg database=grassdata
db.login driver=pg database=grassdata user=lucadelu port=5433
host=localhost
db.login -p
   pg|grassdata|lucadelu|||
cat /home/lucadelu/.grass7/dblogin
   pg|grassdata|lucadelu||localhost|5433
db.tables
   DBMI-PostgreSQL driver error:
   Connection failed.
   could not connect to server: No such file or directory
         Is the server running locally and accepting
         connections on Unix domain socket
"/var/run/postgresql/.s.PGSQL.5432"?
   Connection failed.
   ERROR: Unable to open database <grassdata>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2960&gt;
  Priority: major | Milestone: 7.1.0
Resolution: | Keywords: database, postgresql, db.login
Changes (by martinl):
* milestone: 7.0.4 => 7.1.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/2960#comment:1&gt;
Component: Database | Version: svn-trunk
* component: Datasets => Database
Ticket URL: <https://trac.osgeo.org/grass/ticket/2960#comment:2&gt;
  Priority: major | Milestone: 7.2.0
Comment (by mlennert):
What's the status of this bug ? Would be nice to have it fixed for 7.2.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2960#comment:4&gt;
I imagine that this is the same issue as #3167 which was fixed. Could you
see if you still have this issue ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2960#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: database, postgresql, db.login
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 mlennert]:
you see if you still have this issue ?
Right, seems to be like that. I tested PG database cluster running on port
5433.
db.login dri=pg data=db port=5433
db.tables -p
Worked. Closing, feel free to re-open if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2960#comment:6&gt;
