GDAL
April 19, 2016, 4:53pm
1
#2993: cannot type in directly the input in the r.proj GUI
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
In the GUI of r.proj the entry for the input cannot typed in, only select
from list. Common behaviour, which should apply here too i.m.h.o. is a
combo box where one can type in the name or select from a drop down list
Ticket URL: <https://trac.osgeo.org/grass/ticket/2993> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
April 19, 2016, 7:43pm
2
Priority: normal | Milestone: 7.0.4
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: forms
Changes (by annakrat):
* keywords: => forms
* component: Default => wxGUI
* milestone: => 7.0.4
Ticket URL: <https://trac.osgeo.org/grass/ticket/2993#comment:1> ;
GDAL
September 11, 2016, 6:56pm
3
Priority: normal | Milestone: 7.0.5
Comment (by neteler):
Still true also in 7.2:
r.proj --ui
... it is not possible to type into the "input" field (while it works for
"mapset").
Ticket URL: <https://trac.osgeo.org/grass/ticket/2993#comment:3> ;
GDAL
September 12, 2016, 1:07am
4
Comment (by annakrat):
In [changeset:"69444" 69444]:
#!CommitTicketReference repository="" revision="69444"
wxGUI: remove readonly style from r.proj combobox, see #2993
Ticket URL: </ticket/2993#comment:4>
GDAL
April 27, 2019, 11:03pm
5
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.7
Resolution: fixed | Keywords: forms
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2993#comment:7> ;
