[GRASS-dev] [GRASS GIS] #2997: python editor refuses to run script with UI after closing multiple times
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: unspecified
Keywords: python, editor | CPU: Unspecified
Platform: Unspecified |
Steps to reproduce:
# open simple python editor
# load GRASS module example
# run -> GUI is shown
# close dialog
# run -> nothing happens
Reason: `self.running` is still True
Ticket URL: <https://trac.osgeo.org/grass/ticket/2997&gt;
Resolution: | Keywords: python, editor
Description changed by martinl:
Old description:
Steps to reproduce:
# close dialog
New description:
Steps to reproduce:
  1. open simple python editor
  2. load GRASS module example
  3. run -> GUI is shown
  4. close dialog
  5. run -> nothing happens
Ticket URL: <https://trac.osgeo.org/grass/ticket/2997#comment:1&gt;
#2997: python editor refuses to run script with UI after closing GUI dialog
Ticket URL: <https://trac.osgeo.org/grass/ticket/2997#comment:2&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.2.0
Resolution: fixed | Keywords: python, editor
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"68396" 68396]:
#!CommitTicketReference repository="" revision="68396"
pyedit: do not use onDone because it is not executed when GUI is invoked
(fixes #2997)
Now you can run again even if it is already running
which is the same behavior as for normal module calls.
It also uses the same temporary file once it was created
to avoid the need to delete it all the time. It is deleted
when file is actually saved.
Also remove suppression of the GUI interface because we
actually want to get GUI (the parameter does not work, r68395).
Ticket URL: </ticket/2997#comment:4>
Resolution: fixed | Keywords: python, editor, pyedit
* keywords: python, editor => python, editor, pyedit
Ticket URL: <https://trac.osgeo.org/grass/ticket/2997#comment:5&gt;
