[GRASS-dev] [GRASS GIS] #2998: m.nviz.image fails with X Error BadValue integer parameter out of range for operation
operation
Reporter: wenzeslaus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: LibOpenGL | Version: svn-trunk
Keywords: m.nviz.image, NVIZ, 3D, GLX, | CPU: x86-64
  X_GLXCreateContext, g.gui.animation |
Platform: Linux |
G7:m.nviz.image fails to render the image. (3D view in wxGUI works well.)
Generating vector points (fails for any data):
v.random -z output=points n=100 zmin=0 zmax=20
# or
# r.surf.fractal fractal
Running, m.nviz.image:
m.nviz.image vpoint=points vpoint_size=5 vpoint_layer=1 \
   position=0.84,0.16 height=600 perspective=30 focus=172,136,0 \
   output=nviz_output format=ppm size=798,530
The error:
X Error of failed request: BadValue (integer parameter out of range for
operation)
   Major opcode of failed request: 154 (GLX)
   Minor opcode of failed request: 3 (X_GLXCreateContext)
   Value in failed request: 0x0
   Serial number of failed request: 24
   Current serial number in output stream: 29
GRASS version:
> g.version -re
GRASS 7.1.svn (2016)
libgis Revision: 67275
libgis Date: 2015-12-20 07:50:48 -0500 (Sun, 20 Dec 2015)
PROJ.4: 4.9.1
GDAL/OGR: 1.11.2
GEOS: 3.5.0
SQLite: 3.8.11.1
Computer and system info:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 15.10
Release: 15.10
Codename: wily
$ lspci -v # selected lines only
00:02.0 VGA compatible controller: Intel Corporation Sky Lake Integrated
Graphics (rev 07) (prog-if 00 [VGA controller])
         Subsystem: CLEVO/KAPOK Computer Device 2425
         Flags: bus master, fast devsel, latency 0, IRQ 126
         Memory at de000000 (64-bit, non-prefetchable) [size=16M]
         Memory at c0000000 (64-bit, prefetchable) [size=256M]
         I/O ports at f000 [size=64]
         Expansion ROM at <unassigned> [disabled]
         Capabilities: <access denied>
         Kernel driver in use: i915
$ sudo dmidecode -q | grep -iE "Manufacturer|Product Name" | sed
's/[[:blank:]]\{2,\}//g' | sort | uniq
         Manufacturer: Intel(R) Corporation
         Manufacturer: Samsung
         Manufacturer: System76, Inc.
         Product Name: Lemur
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998&gt;
operation
  Priority: normal | Milestone: 7.2.0
Resolution: | Keywords: m.nviz.image, NVIZ, 3D, GLX,
                         | X_GLXCreateContext, g.gui.animation
       CPU: x86-64 | Platform: Linux
Comment (by virtuale71):
m.viz.image fails also on generating a tiff image of a dem raster. Here is
the error report:
         APPCRASH
   application name: m.nviz.image.exe
   application version: 7.0.0.0
   Timestamp application: 5725e1e3
   Error module name: libgrass_ogsf.7.0.4.dll
   Error module version : 0.0.0.0
   Timestamp error module: 5725df0e
   exception code: c0000094
   exception offset: 000000000002c080
   Versione SO: 6.1.7601.2.1.0.256.48
   Local settins: 1040
  Extra information 1: f010
  Extra information 2: f010b8bf1a53840503aacbf5539daf48
  Extra information 3: cb08
  Extra information 4: cb08b57330503ec68eb2a7f62401ed8b
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:2&gt;
operation
Comment (by neteler):
Replying to [comment:2 virtuale71]:
is the error report:
> APPCRASH
> Local settins: 1040
Please post the output of
g.region -p
Perhaps too many rows/cols?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:3&gt;
operation
Comment (by annakrat):
m.nviz.image does not work on Windows: #2114
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:4&gt;
operation
  Priority: normal | Milestone: 7.2.4
Comment (by hcho):
I'm getting the same error while trying to visualize the elevation raster
in the NC sample dataset.
g.region raster=elevation
m.nviz.image elevation_map=elevation output=elev perspective=15
operation)
   Major opcode of failed request: 153 (GLX)
glxgears works fine.
Also, wxGUI 3D view doesn't show 3D rasters. Maybe, I don't understand how
to use it. I followed the example in r.to.rast3elev and tried to visualize
threelayer output. I can only display the wire box. I thought it's related
to m.nviz.image?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:10&gt;
operation
Comment (by hcho):
r72939 should fix this issue. Indirect rendering is disabled by default
since Xorg 1.17. Nviz now uses direct rendering. If we need to support
indirect rendering, we can add an environment variable later.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:11&gt;
operation
      Type: defect | Status: closed
Resolution: fixed | Keywords: m.nviz.image, NVIZ, 3D, GLX,
Changes (by hcho):
* status: new => closed
* resolution: => fixed
Comment:
For our record, there are three locations that create direct/indirect
rendering contexts:
./raster3d/r3.showdspf/new_init_graphics.c:1045:
glXCreateContext(XtDisplay(widget), vi, 0, GL_TRUE);
./raster3d/r3.showdspf/new_init_graphics.c:1093:
./lib/nviz/render.c:116: rwin->contextId =
glXCreateContext(rwin->displayId, v, NULL, GL_TRUE);
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:12&gt;
operation
      Type: defect | Status: reopened
Changes (by neteler):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:11 hcho]:
(reopening for potential backport to 7.4/7.2)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:13&gt;
operation
Changes (by hcho):
* status: reopened => closed
Comment:
In [changeset:"72949" 72949]:
#!CommitTicketReference repository="" revision="72949"
nviz: Fix #2998 (merge from trunk r72939)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:14&gt;
operation
Changes (by hcho):
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:15&gt;
operation
Changes (by hcho):
Comment:
In [changeset:"72950" 72950]:
#!CommitTicketReference repository="" revision="72950"
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:16&gt;
operation
Comment (by hcho):
r72949 & r72950 backport it to 7.2 & 7.4.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:17&gt;
operation
Unfortunately, it is not working for me, the error is not there anymore,
but I get black image, nothing in there (both tif and ppm). I am using
Ubuntu 16.04.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:18&gt;
operation
Comment (by hcho):
Oh! I'm on Linux (Slackware 14.2). Is there a way to reproduce your issue?
Any sample data set and command line? Maybe, it was related to my mistake
in write_img.c, which is just fixed in r72951?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:19&gt;
operation
Replying to [comment:19 hcho]:
issue? Any sample data set and command line? Maybe, it was related to my
mistake in write_img.c, which is just fixed in r72951? Please try r72951.
I am afraid it perhaps might be specific to hardware? I am running simple
command
m.nviz.image --overwrite elevation_map=elevation output=/tmp/test for=tif
I will try a different linux computer.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:20&gt;
operation
Comment (by hcho):
Replying to [comment:20 annakrat]:
simple command
for=tif
Yeah, that command works for me with the NC sample data set (attached).
Maybe, it's GPU specific or its Xorg driver? My laptop has Integrated
Intel HD Graphics 620 and Xorg uses the "intel" driver. Let me try the
same command on my desktop (NVIDIA GTX 1050Ti).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:21&gt;
operation
Changes (by hcho):
* Attachment "test.png" added.
Test on Integrated Intel HD Graphics 620, Xorg 1.18.3, Mesa 11.2.2 on
Linux kernel 4.14.39.
operation
This is my specs: Mesa DRI Intel(R) Haswell Mobile, Xorg 1.18.4, Mesa
12.0.6, Linux 4.8.0-58
I tried today on a different laptop with nvidia and it worked there.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:22&gt;
operation
Comment (by hcho):
Linux 4.4.132, GeForce GTX 1050 Ti, Xorg 1.18.3, Mesa 11.2.2
Nouveau (open source) & NVIDIA (proprietary) drivers work fine.
What was the other one that didn't work?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:23&gt;
operation
Comment (by hcho):
Maybe, this is also related to glViewport in #3600.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2998#comment:24&gt;
