#3002: r.tile incorrect overlapping
Reporter: aardgoose | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Default | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: MSWindows 8 |
r.tile using an overlap of 1 overlaps adjacent tiles by 2 columns,
illustrated by the r.info extract below. Resolution is 32m and overlap S
-N of is 64m.
| Map: TEXTZ-000-000@SK Date: Tue Apr 26 11:52:03 2016
| Title: Tile 0,0 of SK32M ( TEXTZ-000-000 )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: DCELL
| Rows: 100
| Columns: 100
| Total Cells: 10000
| Projection: Transverse Mercator
| N: 390031.98976328 S: 386833.0134357 Res: 31.98976328
| E: 403166.31130064 W: 399968.01705757 Res: 31.98294243
| Range of data: min = 149.215669047674 max = 373.009547999747
| Data Source:
| SK32M
| Data Description:
| generated by r.tile
| Comments:
| r.tile --verbose input="SK32M" output="TEXTZ" width=98 height=98
ove\ |
| rlap=1
| Map: TEXTZ-001-000@SK Date: Tue Apr 26 11:52:03 2016
| Title: Tile 0,1 of SK32M ( TEXTZ-001-000 )
| Timestamp: none
| Data Type: DCELL
| Rows: 100
| Columns: 100
| Total Cells: 10000
| N: 386896.99296225 S: 383698.01663468 Res: 31.98976328
| Range of data: min = 127.552440611917 max = 409.305838621671
| Data Source:
| SK32M
| Data Description:
| generated by r.tile
| Comments:
ove\ |
| rlap=1
-N of is 64m.
2016 |
| Timestamp: none
| Data Type: DCELL
| Rows: 100
| Columns: 100
| Total Cells: 10000
| Data Source:
| SK32M
| Data Description:
| generated by r.tile
| Comments:
ove\ |
| rlap=1
2016 |
| Timestamp: none
| Data Type: DCELL
| Rows: 100
| Columns: 100
| Total Cells: 10000
| Data Source:
| SK32M
| Data Description:
| generated by r.tile
| Comments:
ove\ |
| rlap=1
New description:
-N of is 64m.
| Timestamp: none
| Data Type: DCELL
| Rows: 100
| Columns: 100
| Total Cells: 10000
| Data Source:
| SK32M
| Data Description:
| generated by r.tile
| Comments:
ove\ |
| rlap=1
| Timestamp: none
| Data Type: DCELL
| Rows: 100
| Columns: 100
| Total Cells: 10000
| Data Source:
| SK32M
| Data Description:
| generated by r.tile
| Comments:
ove\ |
| rlap=1
