GDAL
April 26, 2016, 1:40pm
1
#3004: r.volume: ERROR: Reading raster map <xy> request for row z is outside
region
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.4
Component: Raster | Version: svn-trunk
Keywords: r.volume | CPU: All
Platform: All |
mentioned first on the [https://lists.osgeo.org/pipermail/grass-
dev/2016-April/079919.html dev ML]
a reproducible test case with the NC sample dataset
g.region -p vector=geology@PERMANENT res=25
v.to.rast input=geology@PERMANENT output=myrast_to_check use=attr
attribute_column=GEOL250_
r.mapcalc "myrast_to_clump = myrast_to_check@user1 /
myrast_to_check@user1"
r.volume input=myrast_to_check@user1 clump=myrast_to_clump@user1
ERROR: Reading raster map <myrast_to_clump@user1> request for row -7 is
outside region
tested with
System Info
GRASS version: 7.1.svn
GRASS SVN revision: r68309
Build date: 2016-04-26
Build platform: x86_64-w64-mingw32
GDAL: 2.0.2
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
but it's also in linux debian.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
April 29, 2016, 12:21pm
2
region
Resolution: | Keywords: r.volume
CPU: All | Platform: All
Comment (by neteler):
Confirmed on my Linux box:
The issue seems to happen in this loop (check briefly with gdb debugger):
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.volume/centroids.c#L77
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004#comment:1> ;
GDAL
May 4, 2016, 2:11am
3
region
Comment (by annakrat):
Fixed integer overflow in r68376. Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004#comment:2> ;
GDAL
May 4, 2016, 9:15am
4
region
Comment (by hellik):
Replying to [comment:2 annakrat]:
Fixed,closing ticket.
Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004#comment:3> ;
GDAL
May 4, 2016, 9:15am
5
region
Type: defect | Status: closed
Resolution: fixed | Keywords: r.volume
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004#comment:4> ;
GDAL
May 4, 2016, 9:16am
6
region
Should be backported?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004#comment:5> ;
GDAL
May 4, 2016, 11:10am
7
region
Type: defect | Status: reopened
Changes (by martinl):
* status: closed => reopened
* resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004#comment:6> ;
GDAL
May 4, 2016, 9:03pm
8
region
Changes (by annakrat):
* status: reopened => closed
Comment:
Backported in 68378.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3004#comment:7> ;
