[GRASS-dev] [GRASS GIS] #3005: v.to.rast allow to use label_column alone
Reporter: marisn | Owner: grass-dev@…
Priority: minor | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: v.to.rast | CPU: Unspecified
Platform: Unspecified |
At the moment v.to.rast only supports label_column together with
attr_column. It makes perfect sense, still misses one use case - when
attr_column is absent and only labels are present. I.e. when attribute
table contains land use labels but not class codes.
Proposal is to generate codes on the fly if only label column is provided.
How it could work: select labelcolumn from db distinct; Enumerate output
rows; Use row number as a raster category.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3005&gt;
  Priority: minor | Milestone: 7.2.0
Resolution: | Keywords: v.to.rast
Comment (by mmetz):
Replying to [ticket:3005 marisn]:
provided.
You can use v.reclass + v.to.rast, e.g. with the NC dataset
v.reclass in=soils_general@PERMANENT out=soils_reclass layer=1
column=GSL_NAME
g.region -pa vect=soils_reclass res=100
v.to.rast in=soils_reclass layer=1 use=cat label_column=GSL_NAME
or write a script that does the above for any given vector and label
column for general use.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3005#comment:2&gt;
