GDAL
May 2, 2016, 7:23pm
1
#3009: "Quit GRASS GIS" button only exits GUI
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: wxGUI | Version: unspecified
Keywords: "quit grass gis button" | CPU: Unspecified
Platform: Unspecified |
For some time, quitting GRASS from the GUI opens a dialog (see attached)
with buttons to "Close GUI" and "Quit GRASS GIS".
But both do the same thing: quitting the GUI but not exiting GRASS. At
least that is what happens on the Mac. Is this the case on other platforms
too?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
May 2, 2016, 7:24pm
2
Resolution: | Keywords: "quit grass gis button"
Changes (by cmbarton):
* Attachment "GRASS_quit_dialog.png" added.
Quit GRASS dialog
GDAL
May 2, 2016, 7:27pm
3
CPU: Unspecified | Platform: MacOSX
Changes (by annakrat):
* platform: Unspecified => MacOSX
Comment:
Yes, other platforms work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:1> ;
GDAL
April 27, 2019, 11:05pm
4
Priority: normal | Milestone: 7.0.7
Comment (by martinl):
Still relevant?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:4> ;
GDAL
April 28, 2019, 7:58am
5
Comment (by cmbarton):
Yes. Quit GRASS button does not work on the Mac
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:5> ;
GDAL
April 28, 2019, 9:59am
6
Priority: normal | Milestone: 7.6.2
Changes (by martinl):
* milestone: 7.0.7 => 7.6.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:6> ;
GDAL
March 4, 2020, 9:39am
7
Comment (by nila):
This is still an issue with 7.8 branch and master (7.9.dev), with Python
3.8.2 and wxPython 4.0.7.post2.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:7> ;
GDAL
March 4, 2020, 4:23pm
8
Comment (by nila):
I believe I have found the cause of this issue.
In gui/wxpython/lmgr/frame.py:2533-2536 `GMFrame.OnCloseWindowOrExit()`:
if ret != wx.ID_CANCEL:
self._closeWindow(event)
if ret == wx.ID_YES:
self._quitGRASS()
in `self._closeWindow` self (the GMFrame) will be destroyed and
`self._quitGRASS` will never be reached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:8> ;
GDAL
March 10, 2020, 12:59pm
9
Comment (by nila):
I was wrong in my previous assessment.
Now I found the bug and the [https://github.com/OSGeo/grass/pull/408
PR#408] may fix this issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:9> ;
GDAL
March 26, 2020, 1:47am
10
Comment (by annakrat):
Replying to [comment:8 nila]:
> self._quitGRASS()
Are you sure this is not the case? It seems like that would be a problem.
Not sure what the solution would be, perhaps moving the os.kill to the
GMApp OnExit handler.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:10> ;
GDAL
March 26, 2020, 7:52am
11
Priority: normal | Milestone: 7.8.3
Changes (by neteler):
* milestone: 7.6.2 => 7.8.3
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:11> ;
GDAL
July 16, 2020, 7:03am
12
Comment (by nila):
This issue has been solved for bash and zsh terminal with
[https://github.com/OSGeo/grass/pull/722 PR722].
The cause of the problem is that some shells often ignore SIGTERM when
interactive, which is the case - as it seems - for e.g. mac and FreeBSD
shells.
Adding a `trap "exit" TERM` did the trick.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:12> ;
GDAL
July 16, 2020, 7:09am
13
Type: defect | Status: closed
Resolution: fixed | Keywords: "quit grass gis button"
Changes (by nila):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3009#comment:13> ;
