#3010: PyGRASS fails to write vector map with attributes
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: PyGRASS | Version: svn-trunk
Keywords: vector | CPU: Unspecified
Platform: All |
Example taken from a workshop material:
from grass.pygrass.vector import VectorTopo
from grass.pygrass.vector.geometry import Point
point1 = Point(635818.8, 221342.4)
point2 = Point(633627.7, 227050.2)
cols = [(u'cat', 'INTEGER PRIMARY KEY'),
(u'name', 'TEXT')]
with VectorTopo('my_points', mode='w', tab_cols=cols, overwrite=True) as
my_points:
# save the point and the attribute
my_points.write(point1, ('pub', ))
my_points.write(point2, ('restaurant', ))
# save the changes to the database
my_points.table.conn.commit()
gives:
WARNING: Vector map <my_points> already exists and will be overwritten
WARNING: Coor file of vector map <my_points@PERMANENT> is larger than it
should be (18 bytes excess)
Building topology for vector map <my_points@PERMANENT>...
Registering primitives...
0 primitives registered
0 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 0
Number of primitives: 0
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
File "<stdin>", line 3, in <module>
File "/home/anna/dev/grass/trunk1/dist.x86_64-pc-linux-
gnu/etc/python/grass/pygrass/errors.py", line 15, in wrapper
return method(self, *args, **kargs)
gnu/etc/python/grass/pygrass/vector/__init__.py", line 197, in write
cats.set(cat, self.layer)
gnu/etc/python/grass/pygrass/vector/basic.py", line 452, in set
libvect.Vect_cat_set(self.c_cats, layer, cat)
ctypes.ArgumentError: argument 3: <type 'exceptions.TypeError'>: wrong
type
The old API should (must) be accommodated. If the old API is so bad, that
it needs to be replaced (rather than extended), then we should have one
transitional version where both APIs work and the old one gives a warning.
I don't have enough information to make the judgment.
Related to that, the error message does not give much information about
what is going on.
Type: defect | Status: reopened
Priority: major | Milestone: 7.2.0
Resolution: | Keywords: vector, API break, backwards
CPU: | compatibility
Unspecified | Platform: All
Comment (by huhabla):
IMHO the former implementation was close to be a bug that was fixed in
trunk. For every new feature a new category was created by default, except
a category was already attached to the c_cat field in the geometry. It was
not obvious howto use the same category for different features.
Replying to [comment:3 wenzeslaus]:
> The following from r68603 is breaking backwards compatibility between
7.0 and 7.2:
> #!diff
> - def write(self, geo_obj, attrs=None, set_cats=True):
> + def write(self, geo_obj, cat=None, attrs=None):
that it needs to be replaced (rather than extended), then we should have
one transitional version where both APIs work and the old one gives a
warning. I don't have enough information to make the judgment.
what is going on.
Comment (by zarch):
Replying to [comment:5 huhabla]:
I do think that the current version is better than it was.
But it breaks things and this is why I've informally ask to Markus N. if
it would be possible to have a grass addons directory grass70 and
grass72... But he want to avoid to have further differentiation of the
grass folders.
Because the code is not portable between these two versions.
[off topic] Perhaps git would be an option where you use a dedicate branch
for grass6/grass70/grass7x.
Comment (by wenzeslaus):
trunk.
If it was buggy, than there should be a special `if` with an error message
(exception, fatal, assert) which will tell you that you are using old API
which was buggy and you need to change your code.
BTW, the current message is not that good even in context of the 7.2 API
only because you don't know what has the wrong type.
> For every new feature a new category was created by default, except a
This does not seem buggy but as a simple one which not flexible enough for
advanced user but pretty good for new users.
> It was not obvious howto use the same category for different features.
This sounds like a problem with documentation or a need for additional
API, seems like a long jump to breaking backwards compatibility.
Don't take me wrong, I agree that the new API is needed. It just needs
some better handling for the 7.0 API. (We are getting complains about
breaking API for modules between 6.4 and 7.0, so I suppose users care
about backwards compatibility.)
In [changeset:"69809" 69809]:
#!CommitTicketReference repository="" revision="69809"
pygrass: 7.0 API now works even without using kwargs for Vector.write(),
see #3010
Replying to [comment:4 martinl]:
7.0 and 7.2:
> There are much more breakage of backward compatibility between 7.0 and
7.2 (speaking about pyGRASS). This is just one of them.
If there is more, it would be good to have them in
wiki:Release/7.2.0-News#PyGRASSchanges.
For the parts where the feature is a basic feature (like writing
attributes) or it is easy to implement (like switching parameters) we
should keep compatibility like in r69809 (the cat auto-incrementing was
already there).
How to report that to the user is a question. I used
In [changeset:"69832" 69832]:
#!CommitTicketReference repository="" revision="69832"
closes #3010
