#3011: OSGeo4W-winGRASS71 r68376: starting wxgui fails
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.5
Component: wxGUI | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: MSWindows 7 |
error message:
Cleaning up temporary files...
Starting GRASS GIS...
File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\gis_set.py",
line 1200
, in <module>
GRASSStartUp = StartUp(0)
File "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-
unicode\wx\_core.
py", line 7981, in __init__
self._BootstrapApp()
unicode\wx\_core.
py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
line 1175
, in OnInit
StartUp = GRASSStartup()
line 230,
in __init__
self._set_properties(grassVersion, grassRevisionStr)
line 282,
in _set_properties
self.OnSetDatabase(None)
line 929,
in OnSetDatabase
self.UpdateLocations(self.gisdbase)
line 796,
in UpdateLocations
self.lblocations.InsertItems(self.listOfLocations, 0)
line 1152
, in InsertItems
self._LoadData(choices, disabled)
line 1141
, in _LoadData
index = self.InsertStringItem(sys.maxsize, item)
unicode\wx\_contr
ols.py", line 4761, in InsertStringItem
return _controls_.ListCtrl_InsertStringItem(*args, **kwargs)
wx._core.PyAssertionError: C++ assertion "m_count ==
ListView_GetItemCount(GetHw
nd())" failed at ..\..\src\msw\listctrl.cpp(1629) in
wxListCtrl::InsertItem(): m
_count should match ListView_GetItemCount
ERROR: Error in GUI startup. See messages above (if any) and if necessary,
pleas
e report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package,
proba
bly named grass-gui, installed.
To run GRASS GIS in text mode use the -text flag.
Exiting...
Drücken Sie eine beliebige Taste . . .
Ticket URL: <https://trac.osgeo.org/grass/ticket/3011>
