[GRASS-dev] [GRASS GIS] #304: quering disables vector transparency
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
1. set a transparency for a vector map conatining a polygon
2. query the polygon in edit mode, or within vdigit - the transparency is
gone due to highlight
This is a problem when there is a writing in the background raster map
which I want to enter into the table as an attribute - one has to remember
to memorize it before a query.
About querying - a polygon query in non-edit mode highlits only the
centroid. Could it highlight a whole polygon, like an edit-query?
Ticket URL: <http://trac.osgeo.org/grass/ticket/304&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
  Priority: major | Milestone: 6.5.0
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by hamish):
* cc: svn-develbranch6 (removed)
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/304#comment:3&gt;
