[GRASS-dev] [GRASS GIS] #3041: Grass Nviz crashes
Reporter: virtuale71 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Tcl/Tk NVIZ | Version: 7.0.4
Keywords: | CPU: x86-64
Platform: MSWindows 7 |
I am using Grass 7.04 standalone. I have made a 3d view of dem raster. How
can I have a high resolution image file of it to work with Photoshop? It
seems that the only tool to have it is Nviz but it always crashes and the
genereated Tiff file that is empty.
If you select a Ppm file it generates a few Kbites file; I can't open it,
but its size can't match with an high resolution image.
Some experiments have been done with previous Grass 6xxx and Grass 7.04 on
windows 10. Result is the same. In older 6xxx Grass version a popup states
that there is a memory issue. We have tried to cut the raster smaller and
smaller but the problem wasn't solved.
  | Type of Map: raster Number of Categories: 0
  | Data Type: FCELL
  | Rows: 2610
  | Columns: 3711
  | Total Cells: 9685710
  | Projection: Monte Mario / Italy zone 1
  | N: 4186765.97697097 S: 4181546.28599823 Res: 1.9998816
  | E: 2344938.10330853 W: 2337516.69538672 Res: 1.99984045
  | Range of data: min = 175.59 max = 672.84
And the error log:
APPCRASH
m.nviz.image.exe 7.0.0.0
   application Timestamp: 5725e1e3
   Module with errors name: libgrass_ogsf.7.0.4.dll
   Version of module with errors: 0.0.0.0
   Module with error Timestamp: 5725df0e
   Exception code: c0000094
   Exception Offset: 000000000002c080
   SO version: 6.1.7601.2.1.0.256.48
   ID local settings: 1040
   Other infos 1: f010
   Extra infos 2: f010b8bf1a53840503aacbf5539daf48
   Extra infos 3: cb08
   Extra infos 4: cb08b57330503ec68eb2a7f62401ed8b
Comand log:
(Mon May 23 17:34:34 2016)
m.nviz.image --overwrite --quiet elevation_map=Gibellina_Vecchia@Ale
height=3886 zexag=1.5 focus=1000,1000,1000 output=C:\Users\Ale\12122.tif
format=tif size=640,480
(Mon May 23 17:34:38 2016) Comando terminato (3 sec)
Would the verbose output be better?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3041&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.0.5
Component: wxGUI | Version: 7.0.4
Resolution: duplicate | Keywords: m.nviz.image
       CPU: x86-64 | Platform: MSWindows 7
Changes (by annakrat):
* status: new => closed
* component: Tcl/Tk NVIZ => wxGUI
* resolution: => duplicate
* keywords: => m.nviz.image
* milestone: => 7.0.5
Comment:
Duplicate of #2114. It should still work in the GUI using 3D view, so you
can try it there. Or on a different platform.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3041#comment:1&gt;
Comment (by neteler):
Replying to [ticket:3041 virtuale71]:
How can I have a high resolution image file of it to work with Photoshop?
If you want a 2D map, then you can also use d.out.file.
Do you want a perspective view?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3041#comment:2&gt;
Comment (by virtuale71):
Yes, I need a perspective view, like the ones you can have on the display.
The problem is that you can only have a low resolution image of it, more
or less of the resolution of a screenshot.
Can this depend upon my system? I have a PC, does somebody knows if there
is the same problem on Mac?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3041#comment:3&gt;
Comment (by wenzeslaus):
Replying to [comment:3 virtuale71]:
there is the same problem on Mac?
m.nviz.image works well on Linux and Mac (except for an error at the end
of rendering on Mac where it reports some error but renders the image).
wxGUI 3D view should give high resolution image when your screen is high
resolution regardless of platform (you still need enough memory for the
data, 64bit version is helpful in this (64bit GRASS GIS is standard on
Linux and it is new on MS Windows, but note that MS Windows depending on
the version artificially limit memory usage in different ways)).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3041#comment:4&gt;
