#305: Add created map into layer tree: errors for import modules
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
1. in preferences set "Add created map into layer tree"
2. try to import using any module, in GUI, = errors
For example, 'v.in.ogr dsn=pomiar.shp output=pomiar' yields:
Details:
Error: Vector map <pomiar@podklady> not found
Moreover, re-running the command with ovewrite will add the layer again
(so after 2 re-runs you have the layer twice on the list, and so forth).
Could this be avoided?
should be fixed in r34836 (6.4), r34837 (7.0).
You can always disable adding new layer into layer tree if you re-run the
same command...
again (so after 2 re-runs you have the layer twice on the list, and so
forth). Could this be avoided?
the same command...
